Working on putting in a dual battery with isolator in my 2003 E350 (6.8L). Reading through Sure Power's instructions, it says that most pre-1999 Ford's must use the exciter post to an ignition-only power source. Then, I've read other people who have not had to use the exciter post in a 2001 Ford (an article in www.ford-trucks.com, no less). Two questions:
1-Do I have to use the exciter in my case, as I cannot find out if I do or not.
2-What to use for the power source if I do? I show hot power to everything from the power distribution box under the hood when the vehicle is even in the off position.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
It seems it depends on what type of alternator you have, and apparently later Fords have the type, where they will not start charging by themselves. They need a little kick of voltage applied to the output of the alternator to make them come "online".
You could try it without hooking it up, and see if it works reliably. If someone got it to work without the excite wire, it may be due to their particular installation, and possibly enough leakage current making the alternator kick in.
I think if you really want it to reliably charge everytime it's started, I would follow the instructions and add an excite wire. This may mean running a small wire through the firewall and into the underdash fuse box if you can't find a source in the engine compartment. You can buy a fuse tap to hook it into a circuit in the box.
Yes, that is the instructions I have. You are probably correct - wire the exciter regardless.
It appears everything is hot in the power distribution box under the hood, including the IGN fuse. Have a good recommendation what circuit is hot (either in the engine compartment or in the fuse box under the dash) when the ignition is on but no power when the switch is in the ACC position?
if i was u i would buy a good one, i put a cheap on in my truck for my stereo and it crapped out about a week later
Matt
Those surepower units look very good( and expensive).
Alternators can sometimes be a little noisy(electrically speaking). I don't know about tying it to the ignition or any of the computer stuff. What about tying it to the power that runs the fuel pump? That's a pretty heavy circuit. You should have a fuel pump relay in a box under the hood.
I tapped the fuel pump relay. Checked the power - no power when off, no power when on acc, no power in on position when the engine is not running, yes power when engine is running. That looks like it will do for the exciter.
Thank you for the help and suggestion. Just waiting on a bit of a cooler day to do all the wiring. 90/high humidity (upstate NY) and I just dont mix
Dan
2003 E350 Extended Explorer hightop conversion
