Help! 2002 Ranger Won't Turn Over (Good Battery, Dash Lights, 2.3L, MT, 40k miles)
Old 07-31-2005, 12:50 AM
2002RangerDriver's Avatar
2002RangerDriver
2002RangerDriver is offline
Cool Help! 2002 Ranger Won't Turn Over (Good Battery, Dash Lights, 2.3L, MT, 40k miles)
Could anybody throw in their two cents on this problem? I have an '02 Ranger that will not turn over even with a good battery. When the key is inserted and turned, all the dash lights and headlights come on but the engine does not turn over. Could it be....
*Power Control Module?
*Ignition Module?
*Key?
*Whatever the part is called that reads the Key's security code (pls advise)
*Clutch Switch?
I am trying to avoid getting the run-around at the dealer and be able to drive to work on Monday! Thanks for your help
Old 07-31-2005, 01:45 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Are the battery cables clean & tight?
Have someone try to start it while you check for 12 volts from the ignition switch at the starter relay.
Old 07-31-2005, 03:09 AM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
Has it faded out over time (i.e. starts got weaker and weaker) or did it suddenly just not start? If it's a manual tranny could be the clutch isn't engaging fully...
Old 07-31-2005, 06:23 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome 2002RangerDriver and RangerPilot, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 07-31-2005, 09:12 AM
Fastronald's Avatar
Fastronald
Fastronald is offline
Start
Check your neutral safety switch.
Old 07-31-2005, 01:02 PM
Dave257's Avatar
Dave257
Dave257 is offline
I think your 02 has patts and that could be keeping if from turning over. It could also be the neutral switch, cables, relays. Have you done anything that would affect the patts? How did the problem start? The part that reads the key code is the power control module and the "antenna loop" around the ign switch.
Dave
on edit: woops,I see its a manual, so it could be the clutch switch instead od the neutral switch..
Old 08-01-2005, 11:38 AM
hunter1988's Avatar
hunter1988
hunter1988 is offline
my 1986 2.9 ranger with an automatic does the same thing but makes a grinding/clacking noise by the passenger front fender... the starter is good. so is the battery...
Old 08-01-2005, 12:35 PM
xlt4me's Avatar
xlt4me
xlt4me is offline
My '04 2.3L Ranger had the starter go bad at 250mi. so I wouldn't rule it out.
Old 08-01-2005, 01:08 PM
teepee542's Avatar
teepee542
teepee542 is offline
hunter1988. The grinding clicking noise is the starter solenoid. THat should be an easy fix to replace.
Old 08-01-2005, 02:33 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
`u can unplug the neutral saftey switch on the back of the clutch pedal and try it then, that would eliminate that problem... then i would test to see if the starter itself is bad... easiest way would be to have 2 ppl and a multimeter and have someone turn it over while u are testing it...
Matt
p.s. yes does it click at all, does the starter motor spin? any noises at all
Old 08-01-2005, 02:35 PM
fordboy_52's Avatar
fordboy_52
if the starter is clicking then it prolly isnt good... sounds like the starter motor is out... u should pull it and take it to a parts store where they can test it on a starter machine
Matt
Old 08-09-2005, 08:32 PM
2002RangerDriver
Thanks for the replies. Turns out that the transceiver in the ignition is bad so it can't read the security code from the key.
Old 06-29-2017, 09:36 PM
Xmedic9's Avatar
Xmedic9
Xmedic9 is offline
Same problem
It's like when you forget to push in the couch, and try to start it, not a sound. Of course I'm pushing in the clutch.
Old 06-30-2017, 09:26 AM
spooktn's Avatar
spooktn
spooktn is offline
I would try the starter relay first,,,quick and easy test
Old 01-17-2018, 11:09 AM
stirfrysteve's Avatar
stirfrysteve
stirfrysteve is offline
Hi. How did you replace the transceiver? Dealer part only? Did you have to get your keys reprogrammed? Thanks. trying to troubleshoot my no crank no start no click problem.
Quick Reply: Help! 2002 Ranger Won't Turn Over (Good Battery, Dash Lights, 2.3L, MT, 40k miles)
