Suddenly Loud
Old Jul 30, 2005 | 07:29 PM
tums20's Avatar
tums20
Suddenly Loud
I am new to owning a diesel, 1996 F250, it was my grandfather's truck. I was driving in traffic and all the sudden the engine got real loud. Luckily I was 2 miles from home so I could get it there.
No warning lights came on, and it seemed to be running fine though I was being as gentle as possible due to the noise level. My guess is something in the exhaust system came loose but I was hoping someone might have some suggestions. Any help would be appreciated
Old Jul 30, 2005 | 07:48 PM
RubberDuck's Avatar
RubberDuck
Is it like knocking loud, or vroom vroom loud. I would crawl under the truck and give the exhaust a good once over. Look under the hood at the turbo and make sure the down pipe didn't come loose. By the way, welcome to FTE. Let us know what you find.
RubberDuck
Old Jul 30, 2005 | 07:50 PM
JNygard's Avatar
JNygard
Could of been just the cooling fan kicking on.
Old Jul 30, 2005 | 08:28 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
was it like a loud howling noise (such as a fan spinning 2000-2500 RPM behind the radiator) (haha)*
or was it more of a louder exhaust tone? maybe the chrome muffler bearing that holds the downpipe to the radiator came off the oil pan...
Old Jul 30, 2005 | 08:31 PM
tums20's Avatar
tums20
Thanks for the info about the turbo, Ill check the down pipe. As far as noise, I am pretty used to the diesel engine before this happened and it still seemed to run normal, though I was focusing on gauges and trying to keep the rpms on the lower side to be as quiet as possible (though it didnt matter). Best description I can come up with is it went from a yamaha to a harley (volume wise) in 15 seconds.
Old Jul 30, 2005 | 08:39 PM
PowerstrokeJunkie
were you driving slowly in city traffic where the engine could possibly run hot enough where the fan had to kick in? my fan runs on my tuck when i start it up and drive it, it disengages at like 1750 rpm when accelerating...
Old Jul 30, 2005 | 08:42 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
might have lost muffler- been there done that one
Old Jul 31, 2005 | 12:25 PM
tums20's Avatar
tums20
Thanks for all the info, I had my first chance to look around this morning and found the problem. My belt tensioner seems to have broken and the unit was pulled forward so the fan was hitting the pulley. Gonna have it towed to the dealer to fix it, I cant seem to budge the unit.
Old Jul 31, 2005 | 03:19 PM
wayfastwhitey's Avatar
wayfastwhitey
Well a fan hitting on a pulley sure would make a loud noise! :-) I hope everything is fine and you only have to fix a couple little things and nothing to serious
Old Jul 31, 2005 | 03:54 PM
LONEPINERON's Avatar
LONEPINERON
Hey I believe the bolt for the tensioner is left hand thread. May be reason you can't break loose. It was on my '90 f250 with 460. Good luck.
LPR
Dutch602
1997 - 2003 F150
Jul 31, 2016 02:20 AM
kemerick
Jun 22, 2016 11:09 AM
jrcochranusa
6.4L Power Stroke Diesel
May 23, 2016 08:23 PM
tom18287
6.7L Power Stroke Diesel
Jan 20, 2014 09:40 AM
Whisker
18
Aug 15, 2013 08:22 AM
