emissions ?
Old Jul 30, 2005 | 06:17 PM
77'CrewCabOneTon4X4's Avatar
77'CrewCabOneTon4X4
Question emissions ?
alright, im just trying to get a grasp on this whole 73-79 emissions cutback. i know that they changed the heads to drop compression, did something or another to the timing (what, im not sure, and what the change did) and they 'retarded' the cam( again, i have no clue what is meant by 'retarded' or what the change did) can anyone clear this up for me? or point me in a direction where these answers lye? thanks
Old Jul 30, 2005 | 06:35 PM
fasthauler's Avatar
fasthauler
Yup, ur on the right track. The compression in lower and the cam is retarded. That is why a lot of the guys buy the timing chain set for the earlier engines. If you know a guy at a parts house well enough go in and ask him to see a timing chain set for a 70 460 and a set for a 77 460. Pull the crank gear out of the sets and look where the timing mark is in relationship with the key slot. You will see the difference. I have heard guys reporting 30% improvement in power by putting the earlier set in their engines. I think this is an exaggeration because I certainly didn't see that kind of an improvement with mine. You do get an improvement in low end torque. So if you are towing or off road it is worth it.
Old Jul 30, 2005 | 06:44 PM
77'CrewCabOneTon4X4
thanks for the info, but what about the cam? what is ment by it being 'retarded'?
f100beatertruck
Dec 27, 2012 08:27 PM
bchlr240sx
New Member Introductions
May 27, 2009 08:02 PM
muscletruck7379
Nov 25, 2006 07:21 AM
the law
Nov 20, 2002 08:03 PM
m1
Apr 7, 2001 03:41 PM
