Comet the color back
Old Jun 23, 2005 | 10:22 PM
dylan1952's Avatar
dylan1952
Question Comet the color back
This may be something all ready out there. A friend with a faded pickup made his paint job look pretty good again until he can get a fresh paint job by using a can of Comet and rubbing it out, then used a light rubbing compound then waxing it. I was very impressed by the results for a "quick fix". Has anyone ever done this or seen the results?
Dylan1952
Old Jun 23, 2005 | 10:41 PM
rogerf100's Avatar
rogerf100
I haven't seen that trick. I have used a product called TR3 Resin Glaze. It goes on like liquid wax or polish. Drys to a haze then wipe off. It worked real good on oxidized paint finish. Made it look new. Haven't been able to find it in stores anymore. Guess it worked too good.
Old Jun 23, 2005 | 10:46 PM
mr4speedford's Avatar
mr4speedford
roger, you can get it online. When I did a search, quite a few others seem to really like this stuff. click here for the product -4speed
Old Jun 23, 2005 | 11:07 PM
rogerf100's Avatar
rogerf100
Thanks 4speed, I remember the blue label.
Old Jun 25, 2005 | 05:12 AM
boilerbots's Avatar
boilerbots
Was the paint old Enamel that was probably several layers thick?
It seems that the enamel paints might be soft enough to be removed with something abrasive. It also seems to be prone to getting that chalky white build up on the surface.
My old Bronco looks this way right now. I imagine the commet simply removed a bit of surface crud and got down to something fresher looking. Maybe I should wash it with a scotch brite pad, would probably have the same effect.
Old Jun 25, 2005 | 08:33 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Rubbing compound is what you need to freshen up a faded paint job. It is a paste that removes the top layer of faded paint. Used it on a few old trucks. I buy it at places that sell car wax.
Old Jun 25, 2005 | 11:49 AM
Fomoko1's Avatar
Fomoko1
Rubbing compound works the best for me, sometimes 2 or 3 applications are needed. Scotch brite may leave scratches in the paint.
Old Jun 25, 2005 | 02:19 PM
rogerf100's Avatar
rogerf100
I used TR3 on a VW van that had a very chalky paint finish on a gold/yellow and white color paint. I just wiped it on and buffed it off when dry. It worked great, just as if I had spents hours using rubbing compound. When I drove it to work everyone thought I had it repainted.
Old Jun 25, 2005 | 03:06 PM
Fomoko1's Avatar
Fomoko1
rogerf100, sounds like TR3 is great stuff, will have to keep look for it. Never heard of it before now.
Old Jun 26, 2005 | 07:05 AM
Earl's Avatar
Earl
Morris, here is an on-line source http://midwayautosupply.com/searchby.asp?txtSearch=TR3&select1=mfg. You probably can locate other sources from this web site.
Old Jun 26, 2005 | 01:48 PM
Fomoko1's Avatar
Fomoko1
Thanks for the link, there is alot of products here!
Old Jun 27, 2005 | 07:47 AM
truckfarmer's Avatar
truckfarmer
There is a wax-like product (made by Turtle I think) called "Color Back". I have used it on some very oxidized vehicles and it worked great. The cuticles around your finger nails may match the truck for a while. It is available anywhere wax is sold.
Old Jun 28, 2005 | 02:14 PM
AXracer's Avatar
AXracer
Comet is about the same abrasiveness as course (hand) rubbing compound, but the rubbing compounds have material added that helps keep it from drying too quickly or clumping. Ok quick fix for an old oxidized paintjob you don't plan on keeping too long.
Old Jul 31, 2005 | 12:02 AM
rogerf100's Avatar
rogerf100
I found some TR3 at Pepboys. Going to try it on my 1961 fiberglass boat. Says it works on fiberglass too.
Old Jul 31, 2005 | 01:08 AM
WillyB's Avatar
WillyB
Any of the abrasives work well on the old style enamel or lacquer paint - but get them near the new style paints with a clear coat and you will kill your paint job fast.
