Sponsored by: Kumho
Sticky Drum
Old Jul 29, 2005 | 10:21 AM
seventyseven250's Avatar
seventyseven250
Sticky Drum
On my 77 2wd F250, does anyone have any advice for removing the drums? I know I'll probably have to retract the shoes, but I'm not really sure how. After I do that, should it come offf pretty easy or will I have to use a hammer and heat to persuade it?
Old Jul 31, 2005 | 11:44 PM
Ecuri's Avatar
Ecuri
There is an star adjuster wheel that you need to turn to release some tension. It is accessed through a slot at the bottom, inside of the backing plate. It may have a rubber cover that need to be popped off. Use a brake adjuster tool or a flat blade scredriver to turn it. Start at the top and make it turn towards the earth to loosen. Heat is of no use. Hammering on the drum can crack it. Pull and wiggle and use a wood block with a small sledge and alternate sides. I had some so bad on a truck that sat for years, I just smashed them with a sledge and got new ones. GL
Old Aug 4, 2005 | 09:11 AM
seventyseven250
Clearly I didn't look close enough. Turns out I have the Heavy Duty axle and the drum is integral to the hub. According to haynes, and my eyes now that I'm usisng them, I need to remove the hub retaining flange and half-shaft to get the drum off. Yipee!
Old Aug 15, 2005 | 01:48 PM
seventyseven250
Anyone have any advice for doing this? I've never dealt with heavy-duty drum brakes before. I'm basically trying to inspect them because I have some concerns about the upkeep this truck got from the PO. What should I be looking for?
Is there some kind of seal around the axle or something that needs to be changed? To me, it looks like the hub retainer cover holds the fluid in. I'll be changing the diff fluid at the same time also.
If anyone knows anything about this, let me know, because I'm just guessing at this point.
carchub
13
Aug 7, 2014 03:27 PM
MUJA1001
35
Dec 12, 2010 08:32 PM
teardropty
Nov 14, 2010 03:47 PM
64dave
Sep 20, 2007 07:23 AM
cowboysoldier
Sep 25, 2005 07:42 PM
