Hub Removal
Old Jul 29, 2005 | 12:28 AM
77F-150's Avatar
77F-150
Question Hub Removal
Im trying to get the hub removed from the rotor cause the hub is bent a little. The problem is that my passenger side, the bolts are stripped and ya cant screw in a lugnut and rite now i only have three on holding my tire but i have a different rotor and hub but the hub on there is bent at the tip. Do you guys know how to remove these, i've been wacking at it with a rubber mellet but no dice?
Old Jul 29, 2005 | 09:11 AM
mark a.'s Avatar
mark a.
You have to drive the old studs back out. Then the hub will separate from the rotor.
Old Jul 29, 2005 | 02:02 PM
77F-150's Avatar
77F-150
Thanks, i figured it out after staring at it for awhile and found out thats what you have to do.
