Swapping Trannys
Old Jul 17, 2005 | 05:08 PM
straight 6's's Avatar
straight 6's
Swapping Trannys
Okay, I loved my 4 speed w/OD in my 1992. I want to make the swap into my current truck can i do it? They are both manual trannys
"Old" truck: 1992 F-150 with 4.9L exxtended cab short box. It has the 4 w/ OD mazda tranny.
current truck: 1986 F-150 with 4.9L standard cab full box. Transmission code from door jamb is "B." It has a 3 w/OD tranny.
I think I remember reading somewhere that the bell housings had the same patterns from the 70's untill end production making it a failrly simple swap. Any comments? Or suggestions?
6's
Old Jul 18, 2005 | 02:12 PM
85e150's Avatar
85e150
Keep the Mazda trans. Why would you want the "Grand Canyon Special" with a huge gap between 2nd and 3rd in place of a 5 gear???
Old Jul 29, 2005 | 11:49 AM
straight 6's
Other Way.
I'm going the other way. Junking the 3 w/OD and putting in the 4 w/Od. I loved the 5th gearing when I had it and I want it back.
6's
Old Jul 29, 2005 | 03:04 PM
85e150's Avatar
85e150
It should be bolt in if you have a juice clutch already. Bells are the same pattern. Misunderstood your first one. Wish I had a M5OD or a ZF sitting around to replace my 4 speed.
