Sponsored by: Real Truck
Clutch Pedal Hanging
Old Jul 28, 2005 | 02:35 PM
Big Orn's Avatar
Big Orn
I've searched here and have found nothing that relates to this, so I guess I'll have to call on y'all:
See sig line below for truck. Just over 100k miles on it and the clutch pedal does not travel all the way back up after I depress it. It hangs about halfway and I have to pull it up with the toe of my boot. I've sprayed the pivot with WD40 - No help.
Any suggestions besides removing the pedal and doing exploratory surgery?
Old Jul 28, 2005 | 02:38 PM
iskybantilus's Avatar
iskybantilus
not sure on super duty's, but i know on the older style there was a bushing issue of some sort, my brother had to get an updated replacement for his 97 HD 250 diesel 5 speed.
Old Jul 28, 2005 | 04:48 PM
Big Orn's Avatar
Big Orn
Thanks, Dominic - I was afraid of that. Don't look like a hard job, though.
Looks like I have another job for the weekend.
Old Jul 28, 2005 | 07:03 PM
ColtM4's Avatar
ColtM4
Dunno if the 5sp and 6sp are similar in design, but that happend to me and meant the master or slave cylinder going out. Replaced as an entire assembly on the 6sp. Slave, master and the tubing that connects the two come out as one unit, and no need to bleed the system as it comes prefilled.
Old Jul 28, 2005 | 09:10 PM
Go Devil's Avatar
Go Devil
Squeaky Clutch Pedal
Is WD40 the best thing to put on the moving parts of the clutch pedal? Mine is squeaky, but does not stick.
Old Jul 28, 2005 | 09:20 PM
4wd's Avatar
4wd
My old '99 SD did the same thing at 80,000 mi. I started lubing the lever's actuator arm bushing with wd-40, then as that seemed to attract dirt and complicate the sticking, I switched to a dry silicone spray lube that worked real well, till one night...the linkage fell completely out of the clutch lever (bushing completely let go) and the clutch pedel went to the floor with nothing disengaging!! After killing it with the brake, I got out my flashlite and was able to get it home by duct taping the lever in place to the arm, and got a replacement bushing the next day...Suggest you replace the bushing immediately. Don't waste time trying to lube it, it is shot.
Old Jul 28, 2005 | 09:23 PM
Go Devil's Avatar
Go Devil
Does the bushing cost much, and how hard is it to change out?
Old Jul 29, 2005 | 02:06 AM
4wd's Avatar
4wd
Took it to the dealer. He had the bushing in stock, and changed it out for me. If I remember the entire bill was around $38. But that fixed it. No more clutch noises, draging, or lubing.
Old Jul 30, 2005 | 09:23 AM
tripod's Avatar
tripod
I just changed mine-$8.
Old Aug 1, 2005 | 10:11 AM
Big Orn's Avatar
Big Orn
Thanks for the replies. I have the bushing and am ready to install it when my Honey-do's dwindle a tad...
Part #E7SZ7A581A at a cost of $6.97 plus tax.
Vette1976
May 25, 2017 10:35 PM
AbandonedBronco
Apr 23, 2017 11:07 AM
53fordman1
Jul 28, 2016 12:01 AM
53fordman1
Jul 26, 2016 12:18 AM
newguy399
15
Jul 26, 2015 08:03 AM
