Sponsored by: Real Truck
Tie downs
Old Jul 27, 2005 | 09:46 PM
Drone Leader's Avatar
Drone Leader
Tie downs
Anyone have any suggestions on steak pocket tiedowns?
I've got a set of four of the expanding rubber block tiedowns in a blister pack that I'd rather not use. I suppose I could trade for something that uses a dual plate system or simply toss them out like the trash they are. I've seen a couple of alternatives at JC whatever's site, but the pictures don't give me enough detail to get another set of POSs I don't want to use.
Old Jul 28, 2005 | 06:00 AM
bgrover's Avatar
bgrover
I bought a set of Bully tie downs (JC Whitney# ZX494856U) but from my local custom shop. I really like them. On my SD with the plastic bed tops it is actualy flush with the top. If I can remember when I get home I'll take some pictures and post them. Here is the picture from Whitney's website.
Old Jul 28, 2005 | 08:40 AM
Drone Leader
Spring loaded?
I haven't seen the spring loaded kind. I saw a similar type that the hook rolled / folded up (actually, it'd fall back into storage position if you didn't have a strap providing tension to it). Unfortunately, I haven't seen those on-line.
Any issue with corrosion in PA? (My twist in place chrome ones started showing rust after their first winter in Ohio. I'd kind of worrie about the spring causing dis-similar metal corrosion.)
I'd also be concerned with dirt, crud, whatever causing issues with the release mechanism.
Old Jul 29, 2005 | 05:55 AM
bgrover's Avatar
bgrover
In the year I've had them they still look good. I noticed a couple of spots on one, I don't believe it is rust just some discoloration. They worked well all last winter I never seemed to have a problem getting them to pop up when I needed them.
Didn't make it home last night, forgot about a party I had to go to. I'll get the pictures this weekend and post them.
Old Jul 31, 2005 | 06:17 PM
bgrover's Avatar
bgrover
Hopefully these pictures will workout ok. Here is one of the tiedowns (drivers side rear of bed). Pictures are of it in the closed and open position.
Old Jul 31, 2005 | 06:26 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Angry
Speaking of stake pockets, where can I find some steel tubing to fit them? My '05 F250 pockets measure approx 1-5/8 X 2-1/4 inches, what an odd size.
Only need about 2-3 feet of thinwall, say 4 gauge rectangular. Guess I'll have to make it - oh Bother!
Old Jul 31, 2005 | 09:49 PM
Drone Leader
Thanks. They look sharp. Fit pretty well within the cutout on the bedrail cover. Think I'll order a couple of pair.
Don't know what I was thinking about corrosion. Guess I forgot for the moment that I'm living in the desert southwest for the next few years.
Old Aug 1, 2005 | 03:07 AM
bgrover's Avatar
bgrover
Your welcome, yes with the bedrail cutout they are flush with the top which is what I wanted.
