mirror
Old Jul 27, 2005 | 03:36 PM
68 s-code's Avatar
68 s-code
mirror
Can anyone tell me how to get the metal mounting tab out of the rear view mirror?
That time of year and the heat got it.
I don't see the normal set screw that the older vehicles had, and don't want to force the issue and break it. Its a 95 F-250
Thanks
Old Jul 27, 2005 | 05:52 PM
Rotor's Avatar
Rotor
I guess you mean the whole thing came off the windshield? If so you should try grabbing the mounting plate on the sides with a pair of channel locks and wiggle it left and right while you pull. There is a spring clip in there that can put up a good fight sometimes. Don't hold the mirror boot with any tools or put it in a vise as it will just squeeze it tighter on to the base. You could also try to get a flat screw driver in between the base and back edge of the boot and twist. That might pop it out. Good luck, Karl..
kengarchow
Jun 24, 2014 11:03 PM
in heat
Jun 10, 2012 11:00 PM
betsardinski
Sep 20, 2011 08:44 PM
mach8274
May 15, 2011 11:30 AM
Wakeboarder141
2004 - 2008 F150
19
Nov 3, 2006 03:47 PM
