How to on rear drum brake shoes '97 F350
I cannot speak intelegently about the ABS but I would check the connections of the wires.
On the Drums Though:
I have no diagrams but I can tell you this. Purchase New Hardware. This means springs and clips. I found this out about 3000 miles after I bought my 96 and it wrapped the springs around the drum.
1. Remove both wheels after placing rear end on jackstands.
2. Work both drums off. (They are separate from the hubs. If it is tight you may have to loosen the star wheel. the access is from the rear of the plate.)
3. Using the other side as a reference, begin to remove the tension springs and then the clips that go through the shoe backing plates. Take note the direction of the borrom star wheels orientation.
4. Once the shoes are off, compare the new to the old and install the new adjuster pins. they drive in from the back of the shoe.
5. Using your other side as the reference put the new shoes on with the new hardware and that side is done.
6. Repeat steps 3-5 on the other side now using the clean side and your new experience as a guide.
Other material to get wil be as follows:
2 cans brake cleaner
2 pairs of pliers
a flathead screwdriver
1 good friend to help with the new springs
absence of children for when you hit your knuckles
If you want a diagram, Advance autoparts can print one for free. They also carry the bendix brand of shoes which is the ford factory brand.
2 pairs of pliers
I thought that my drum and hub were one piece until I realized that the previous owner neglected to do anything with the brakes and they had corroded together. Once I got them off, I dropped the assembly on the pavement and they popped apart. The manuals that I referenced said that they stopped the 1 piece assembly in about 1990. ???
animaldawg
08-21-2014 12:53 PM
truszip
07-05-2007 11:01 AM
