Frame width
Old Nov 19, 2002 | 12:30 AM
BULGOD's Avatar
BULGOD
Frame width
Howdy all, ive herd that 77 and up half tons have a wider frame than trucks made b4 77 and a half, i have a 77 4x4 with a broken frame, so im debating on welding it or finding another frame, and i have a 79 2 wheel drive frame lined up, will i be able to use it for my 77? even if it is wider? or will cab mounts and etc not line up? anyways thanks ahead of time.
Old Nov 19, 2002 | 04:49 AM
theonlybull's Avatar
theonlybull
Frame width
frames should be the same width from 73-79, our 77,78, and 79 are all the same. the 2wd frame will need some work to be able to use it, the 4x4 is boxed in the front corner, and has a different x-memeber.
Old Nov 19, 2002 | 06:03 AM
electricmaniac2's Avatar
electricmaniac2
Frame width
[updated:LAST EDITED ON 19-Nov-02 AT 07:05 AM (EST)] I think someone is confused about the F250 High boys...They're the special ones that changed in 77 1/2 to the best of my knowledge. Why not weld and box the frame? I bet you'd have fun trying to break it...LOL.
Old Nov 19, 2002 | 09:25 AM
Dons's Avatar
Dons
Frame width
There are two frames 37 1/2 wide and 34 1/2 wide...
Old Nov 19, 2002 | 06:03 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Frame width
(Highboys 60's - 77 1/2 F250's) frames are narrower behind the cab than later 77 1/2 - 79 F250's. I belive the diff is 4". 38" in front and 34 in back. All cabs and beds will swap, the beds will need new holes drilled in them though... The F150's all have the same width frame.
79 250 Ranger Lariat 4wd 400 C6 3.55's 33x12.5 16.5's on slots
Old Nov 19, 2002 | 11:34 PM
BULGOD's Avatar
BULGOD
Frame width
Ok thanks guys, im looking at going ahead and welding my current frame for now, and then once this truck is done, its gonna be fun time, as im gonna tear the high boy down for a frame up i think.
Old Nov 20, 2002 | 12:19 AM
Superdave's Avatar
Superdave
Frame width
red450ih
Mar 8, 2015 04:33 PM
redneck_rolemodel
Jul 10, 2014 01:26 PM
Ford4me302
Mar 17, 2005 11:59 AM
fordaholic460
May 22, 2003 03:30 PM
matt w
1966 - 1977 Early Broncos
Jun 7, 2001 01:11 AM
