Exhaust ( muffler)
Old Jul 26, 2005 | 09:48 PM
gunfighter1's Avatar
gunfighter1
Question Exhaust ( muffler)
I was told that if you remove the muffler the truck would tow better and run cooler. Is this true and would it be to noisey.
bob
Old Jul 26, 2005 | 10:11 PM
johnny8's Avatar
johnny8
replace your stock muffler with the walker big truck muffler if you don't want to spend a lot of $$ but you want to improve the exhaust flow and lower the egts...
Old Jul 26, 2005 | 10:13 PM
fishmanndotcom's Avatar
fishmanndotcom
on a powerstroke it's not all the more noisey at idle but when hitting high RPM's it does start to rumble. but it sounds really good! yes you will lower your egt's since the muffler isn't there to hold in heat and backup exhaust.
i run a tymar 3-3.5" DP with a 4.5" straight pipe all the way to behind the rear axle. i love it.
-cutts-
Old Jul 26, 2005 | 10:49 PM
arninetyes's Avatar
arninetyes
Gunfighter1, it depends on the year of your truck. If you have an OBS (original body style), the muffler really isn't bad. It is a straight through design and a Walker BTM won't give much improvement. However, the squashed downpipe is a disaster and needs to be replaced right away. A 3" DP will fit with only very minor mod to the firewall.
If you have a 99 or later Super Duty, they come with a nice, smooth 3 1/2" DP (which reduces to 3" next to the firewall), but have a crappy and restrictive reverse flow mufller. If you have a 99 or later, replace the original muffler with Walker BTM for a nice improvement in EGT and sound.
Old Jul 26, 2005 | 10:51 PM
opnekryan's Avatar
opnekryan
If you have a cat on there it won't sound a whole lot different just a little louder in the high RPM's like fishman said. I removed my muffler before I removed the cat, and the cat make a much larger difference in sound!!
Old Jul 27, 2005 | 08:12 AM
rmilchman's Avatar
rmilchman
I removed my muffler and like the sound. When I was thinking about doing it someone sent me a wav file. I've posted it for others, www.milchman.us/nomuffler.wav
Old Jul 27, 2005 | 06:15 PM
gunfighter1
BTW my truck is a 1999 F250sd built late in the year.
The sound of the truck with out the muffler is sweet.
Old Jul 28, 2005 | 07:14 AM
rmilchman's Avatar
rmilchman
I'm not sure what year truck the sound clip is from.
wfof250v10
Modular V10 (6.8l)
20
Mar 2, 2025 04:43 PM
06silvercrew
Dec 29, 2010 09:23 PM
mxracer3276
37
Jan 26, 2009 07:28 PM
87carbed
Exhaust Systems
22
Jan 23, 2005 05:34 PM
harem Scarem
Nov 11, 2004 02:11 PM
