kn filter new 2005 f150
Heres the facts that are back up by independent labratory testing. Believe what you want, but K&N makes the best air filters in the world.
http://www.knfilters.com/facts.htm
You can spend $20 every 10,000 miles for the paper air filters. I'll stick to buying a K&N once and getting more power and better milage.
Believe me, if my engine fails due to dirt in the engine, I *WILL* make a post on here about it!
Octane
Octane
There have been a number of articles written on this, and sadly the aftermarket filters NEVER stack up to the stock ones, just the way it is. They do allow more particulates in then a stock one. The good thing is, we all can make our own choice and buy what you like or believe in.
Mike is spot on~!~
And ...Welcome joboblund, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Mike is spot on~!~
Enjoy FTE....and
think about it, if you want to allow more air in you have to???????? either make the filters thiner or make the openings greater... k and n have bigger openings in the paper allowing more crap to get through them... i run the wix air filters and i dont spend but 9$ every other oil change... if its dirty i blow it out once.... easy fix...
i run almost nothing but shale and dirt roads and our filters are rediculus
Matt
Matt
IMHO very rarely is the element itself the restriction to airflow, unless you drive gravel roads, and don't replace it regularly. The OEM filters of today have sufficient surface area to provide good airflow. The restriction (if there is one) to the engine injesting enough air will usually be found in the intake ductwork itself.
For example, I own (5) Fords...my 97 F150 4.6, and 02 Mustang GT 4.6 have restrictions in the ductwork, in addition to rather small ID air silencers poking thru the fender wall to draw cooler air. The replacement K&N air filters (cone filters) for these two applications do not fit very well in the stock air box (and I've told K&N about thier flaw, with no response), as they are manufactured to the small end of the tolerance concerning flange OD size so they are 'guarenteed to fit' all airboxes.
Unfortunatly that means they are a sloppy fit for most, and if you are not careful, don't seal at all. Dropping a K&N by itself into the stock air box of the Stang or F150 will not result in increased airflow to the engine over the OEM filter, it will just capture less dirt.
To increase air flow in these two vehicles, I replaced the entire stock systems with FIPKs & 80mm MAF...a noticable difference (30% larger intake dia on the FIPK). However, I will only run these with a dry charger installed over the K&N. They dry charger is either vacuumed off or washed at every oil change (3-4K). I do occasionally slip the filter off the MAF, and perform a 'white glove' test inside the MAF.
I've run these for about 30K on each vehicle, and the inside of the intake appears to be as clean or cleaner as my other 3 vehicles using the OEM paper filters. (Please note my other 3 vehicles running paper have 45K, 52, 76K mi)
I would never run the K&Ns on these vehicles without a clean dry charger, and a periodic cleanliness inspection.
And I don't do gravel...sometimes a challenge in IA...
Jobo -
Check out http://www.bobistheoilguy.com/airfilter/airtest1.htm - it might help you decide not to run a K&N on the street.
Steve
Steve
Originally Posted by PW01
I was experiencing a "rough idle" problem with my 01 Ranger 4.0, and narrowed it down to the IAC. When I saw how filthy and gummed up the old IAC was, my K&N filter hit the trash and the stock Motorcraft replaced it - how else did all of that crap make it to the IAC?
Originally Posted by Steina
Jobo -
Steve
Steve
Originally Posted by Bob Ayers
Most of the time the oil & dirt from the K&Ns contaminate the MAF sensor.
