Odd engine heating prob.
Old Jul 29, 2005 | 03:37 PM
1975Ford's Avatar
1975Ford
Tsay,
Put a vacuum tee on the vacuum line that runs to the distributor, and from the tee run a vacuum to the EGR. Plug any other vacuums ports not in use.
Try running your engine a 10 degrees BTC, 12 degrees seem a bit high.
On your thermostat housing, trying running a cooler thermostat. Shop around or call the automotive stores and check what store has the lowest temperature rating thermostat.
1975Ford
Hawk180
13
Feb 15, 2012 09:53 PM
gangstakr
May 11, 2011 09:54 PM
dsrtjeeper
Apr 27, 2011 11:06 AM
rmorman
Apr 25, 2011 08:24 AM
qquake2k
Jul 21, 2010 01:42 PM
