Crank Specs
Old Jul 26, 2005 | 05:46 AM
Greywolf73's Avatar
Greywolf73
Question Crank Specs
I was wondering if anyone could tell me the factory specs on a crank ?
The crank is in a 1978 351 windsor.It had .010 stamped on it so i bought .010 mains.But i have no oil pressure at all. So i was thinking maybe when i had the machine work done they may have polished it just alittle to much so i wanted to check it but not sure what factory specs were.
Thanks
Greywolf
Old Jul 26, 2005 | 06:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 26, 2005 | 10:24 AM
beartracks's Avatar
beartracks
The bearings aren't likely to leak that much oil. You may be missing a galley plug or pump drive shaft.
Make sure your oil pressure gauge is functioning before getting carried away. Is there any mechanical noise?
Old Jul 26, 2005 | 01:28 PM
Mil1ion's Avatar
Mil1ion
Maybe check the 90* engine forum Dutch.
That's where Windsor is discussed.
78_f150
Sep 9, 2011 02:24 PM
texasyeti
May 6, 2010 04:28 PM
HappyJack
Jul 6, 2007 01:08 PM
Ranchero460
Aug 16, 2006 01:05 PM
141bpm
May 8, 2005 07:45 PM
