.010-.025 thrust washer source
The gap is .017 over the max and .053 over the min. The factroy side thrust washers are not used in the locker install. I have a set and they measure .037. So they are too thick.
Dose anyone know of a source for hardened side thrust washers between .010 and .025 inches thick?
I installed the same locker in my 94 and there was no problem. The tech at Richmond gear says they have had this problem with the new factory cases from Ford and that there has been problem also with the center pin not being centered properly.
Any help would be welcome.
This with over 922K hard miles without any "hardened" washers.
Seems someone like the LS unit you have has a problem they fail to address
for the proper setup. Makes ya wonder about their product?
http://www.allproducts.com/index.html
^Lots of strange sources and materials.
http://www.nutty.com/
A large hardware store may have sources also.
But anyway the guy working on it found another LS carrier so he is going to try that.
And I did consider seeing if a machine shop could widen the inside of the case so we could run the stock factory Thrust washers. We would need about .017 off each side.
Another idea was to have the stock Thrust washers ground down .017 each. I guess if it is done slowly and "wet" it would retain the hardness.
Sure would be easier if the thrust washers were available in .020 thickness on a shelf somewhere.
Question I have is why hardened shims are required when standard thrust washers are brass/bronze coated on steel?
I like what they say about if you have clearance problems that your case is the problem.
As far as grinding hardened washers you might grind thru as hardness isn't
that thick.
I would rather have a soft material like bearing bronze for shims, should you have a problem in the future the softer shim will not cause damage to the iron thrust surfaces.
I bet your not the only one with this problem, I would check the 4x4 forums and ask them if they also have had this problem.
On a high mileage F250 (843K) with a worn out carrier, spider and side gears I installed 2 washers under each spider plus cut out thicker side gear washers out of bearing bronze. Over 200K miles later with the new owner the rearend still has almost the same slack as installed. This is a open rearend that gets a lot of peg leg spinning hauling firewood.
This is in a LS carrier. Powertrax makes parts for both open and LS carriers. Lock Right makes parts for the open carrier. The Lock Rights I have installed re-use the stock thrust washers. This Powertrax has instructions that says not to use the stock thrust washers.
You know I have worked on a number of these and installed Lock Rights in them. 8.8, Dana 28, Dana 35, and Dana 44. And I have never seen a thrust washer that wasn't all hardened steel.
I was talking to my friend yesterday who talked to a machines friend of his and I finally realized that some differentials had thrust washers made out of different materials.I like what they say about if you have clearance problems that your case is the problem.
that thick.
Guess what we are going to do if need is have the Thrust washers ground and make sure the ground side is against the carrier and the side that still is hardened is against the back of the coupler.
I don't know why they use hardened thrust washers. But I would think the Powertrax (Richmond Gear) wouldn't have a reason to give me bad info. And as I said above all the axles that I have worked on in the past had factory hardened steel thrust washers. Must be some reason for it. If I could find a thrust washer the correct size that was hardened on one side and soft on the other I'd be tempted to try it. But so far I have only been able to locate steel thrust washers down to .030.
Yup! I'm betting the Powertrax unit we have has problems. Don't think I'll use it again.
Thanks for all the help. Good post with good questions are always a help.
