Sponsored by: Real Truck
Front tires wearing funny
Old Jul 26, 2005 | 01:28 AM
boomer377's Avatar
boomer377
Unhappy Front tires wearing funny
I have a 2000 F350 Dually 2wd Lariat with the 7.3 liter Power Stroke and only 41,000 miles. My front tires have been replaced twice now because they are wearing funny and getting chewed up. The rear tires are the original ones from the factory but the fronts get so bad that the vibration comes up through the steering wheel and they make a horrible sound on the road.
Its was aligned with the last set of fronts.
Any suggestions?
Thanks,
Boomer.
Old Jul 26, 2005 | 02:13 AM
Monsta's Avatar
Monsta
Sit. Stay.
What does the tread look like when you have to replace them?
Old Jul 26, 2005 | 04:02 AM
dmp437's Avatar
dmp437
Ditto Monsta's question, where is the wear on the fronts?
Possibilites include sway bar bushings (replace with Energy Suspension No. 4.5186), the shocks are shot or set too soft if you have adjustables, or the ball joints need replacing. Your alignment shop should have caught the ball joints though.
Old Jul 26, 2005 | 06:23 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Any suggestions?
Thanks,
Boomer.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 27, 2005 | 12:10 AM
boomer377's Avatar
boomer377
Thanks for the replys.
The shocks are new, only 5000 miles and tires wear still funny.
On both front tires, the tread wear is as if the alignment is way off but the alignment is fine. My tire guy can't tell what the problem is, Toe, Caster, Camber.
I was told this is a common thing for ford 2 wheel drive duallys. Is it a tire rotation problem maybe?
Old Jul 27, 2005 | 05:39 AM
fomocojoe101's Avatar
fomocojoe101
Find another alignment shop!
mtnxtreme800
2009 - 2014 F150
18
Aug 14, 2015 06:55 AM
Stroker 6.0 fan
Jul 11, 2015 03:29 AM
BoomerTexas70's
Jan 27, 2015 07:34 PM
Boomer23059
6.7L Power Stroke Diesel
Sep 13, 2013 01:35 PM
May 19, 2002 07:15 PM
