Go Back  Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Reload this Page >
have f350 solid front axial, tires wearing on the inside
Old 05-13-2002, 12:10 AM
mgm415
mgm415 is offline
mgm415 is starting off with a positive reputation.
OK have a new to me f350 with a solid front axial. The tires are wearing on the inside, since its a solid axial is there an adjustment for this????
Old 05-13-2002, 02:32 PM
AZ4x4f150
AZ4x4f150 is offline
AZ4x4f150 is starting off with a positive reputation.
there is actually a camber spacer that bolts to the axle.
Old 05-19-2002, 04:37 PM
Rosati's Avatar
Rosati
Rosati is offline
Rosati is starting off with a positive reputation.
Actually the wedges under the axle correct caster only and the camber must be adjusted by bending the axle with a bottle jack and a canteliver type tool. I would suspect your axle is not bent that much but rather your king pins are worn or your bearings are shot.
Lift the front of the truck by placing the jack under the axle and wiggle the tire top and bottom. Watch the spindle for movement and you will be able to tell if the bearings, kingpins or both are bad.
Let us know what you find out.
Old 05-19-2002, 07:15 PM
AZ4x4f150
they make a camber shim that bolts up behind the spindle on SOME solid axles for camber adjustment with the removable spindle
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: have f350 solid front axial, tires wearing on the inside
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
