General Automotive Discussion
freeze plug= soft plug
Old Jul 26, 2005 | 12:55 AM
kulkan's Avatar
kulkan
I see a lot of reference to "freeze plugs" in these forums.
When I was just a lad, about the time transistor radios became popular, my dad said something about these things. My old man was a good mechanic and could tell you which valve on which cylinder was making that slight click that I could hardly hear. And that was walking by from 30 ft away.
He said these things aren't really "freeze plugs". They're from the casting process and are correctly called soft plugs. Of course they DO get pushed out when your engine freezes up at 40 below zero, but that's coincidence. They weren't put there by design to save your block from cracking, and they probably won't.
Nonetheless, my dad has been gone for 11 yrs, and "freeze plugs" still remain. He would have loved the Internet.
Old Jul 26, 2005 | 01:38 AM
fellro86's Avatar
fellro86
I can guarantee without a doubt they will not protect a motor from freezing, I have seen the sides blown out of a block and the "freeze" plugs still in place without so much as a bow... as you stated, they are only for letting the sand out of the casting, nothing more.
Old Jul 26, 2005 | 03:32 PM
vancouverpower's Avatar
vancouverpower
Yep they are for washing the sand out.
Old Jul 26, 2005 | 03:35 PM
76supercab2's Avatar
76supercab2
Absolutely. If your coolant did freeze and the plug popped out, AND your block wasn't damage, you were lucky. The plug didn't save the block, chance did.
Old Jul 26, 2005 | 05:03 PM
captchas's Avatar
captchas
Guest
the correct term is core plug. but though out auto history every body calls them freeze plugs which they are not
Old Jul 26, 2005 | 05:48 PM
sierraben's Avatar
sierraben
Anyone remember the rubber "freeze plugs" with the nut in the middle to secure the plug onto the hole.
Never used one because I didn't trust them to stay in place.
Old Jul 26, 2005 | 07:16 PM
fellro86's Avatar
fellro86
they are still available, but i wouldn't want to use them either. I have something similar for tie downs on my box, junk too...
Old Jul 26, 2005 | 07:40 PM
sierraben's Avatar
sierraben
Those rubber tie down inserts are another joke. IMO.
I guess those rubber freeze plugs are good to carry in your vehicle as an emergency back-up just incase your're out in the boonies and you lose a plug.
But that's about it.
Old Jul 26, 2005 | 08:00 PM
fellro86's Avatar
fellro86
trouble is, you'd have to get the old one out of the way to be able to use them... still just as much headache as replacing it proper. I have seen them used, I just prefer to do it right.
Old Jul 26, 2005 | 08:05 PM
sierraben's Avatar
sierraben
True; but in the middle of nowhere, they could get you to a place to properly fix it; especially if you barely have enough room to get one in and tighten that nut and pray.
Like we said before, don't trust them.
Old Jul 27, 2005 | 11:11 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Install brass plugs by Dorman and never worry about rust out or leaks again. The last motor I sold has 26 years and over 600K on it with the same brass "freeze" plugs.
.....=o&o>.....
