I-beam bushings
Old Jul 25, 2005 | 10:53 PM
lakex1's Avatar
lakex1
Question I-beam bushings
Has anybody replaced the I-beam bushings with out using a hydraulic press.
Old Jul 26, 2005 | 12:42 AM
thesprocket26's Avatar
thesprocket26
Yes. I did on mine. It really sucked. Get it done with a press.
Old Jul 26, 2005 | 10:12 AM
4Cammer72's Avatar
4Cammer72
i got the urethane bushings and with those you leave the factory sleeve in the beam and cut out the old rubber bushing and clean it real good and slide the urethane one into the beam and sleeve. was pretty simple.
Old Jul 26, 2005 | 03:40 PM
Fomoko1's Avatar
Fomoko1
How hard is it to remove the old rubber and how did you do it?
Old Jul 26, 2005 | 05:58 PM
Chevy_Eater's Avatar
Chevy_Eater
I agree, it was well worth the $15 at the machine shop. As much work as I put in it before taking it in, I'm still kicking myself over the waste.
Old Jul 27, 2005 | 07:41 AM
4Cammer72's Avatar
4Cammer72
i took a hacksaw blade and made slices in it, then i made cuts at angles until i got enough out to get a dremmel grinder in and the rest came out easy. i used the dremmel to clean it with a sanding drum too. cleaned out nice and just lubed the new bushing before i put it in and i just slid in with a good push.
94xlt150
Feb 25, 2015 09:53 PM
94 F250 supercab
26
Dec 23, 2011 03:25 PM
andyz77vette
Jul 2, 2011 10:54 AM
wayneasbell
Jan 14, 2007 07:39 AM
loudfords
Jul 25, 2002 05:42 AM
