C6 Stuck in Reverse
Old Jul 25, 2005 | 10:46 PM
mattscot007's Avatar
mattscot007
C6 Stuck in Reverse
I have a 78 F-100 with a 351M. It was tired, so I dropped in a 400 out of an '80 F-250. I pulled the motor out, leaving the trans in place. I wasn't able to get the new motor in place with the trans in place. I unbolted the trans and moved it backwards a few inches, dropped the new motor in, and then slid the trans forward and bolted it up. I started the truck and was setting the timing when the trans shifted itself into reverse and slammed into the donor vehicle parked behind it. I can't get it to shift out of reverse now. I can't feel the linkage shifting the transmission. It is stuck permanently in reverse. The trans was in good working order and was rebuilt about 5000 miles ago. Any Ideas?
Old Jul 26, 2005 | 07:06 AM
stuart1's Avatar
stuart1
When you pushed the transmission back if you didn't remove the lever you could have dislocated the manual valve inside the transmission.
Drop the pan and have a look.
kylechamb
Feb 4, 2016 08:15 PM
hanzy75
May 17, 2015 03:46 PM
406angler
Mar 3, 2014 04:49 PM
Mike54
17
Jun 25, 2013 10:14 PM
Brown Falcon
42
Apr 18, 2012 04:09 PM
