clutch adjustment E50D 5 speed
Old Jul 25, 2005 | 05:14 PM
jeffwecker's Avatar
jeffwecker
is there an adjustment for the clutch cable on the E50D 5 speed trans?
clutch pedal is about 1/2" lower than the brake pedal.
anyone got a diagram/instructions ? thanks!!
Old Jul 25, 2005 | 05:43 PM
andym's Avatar
andym
E5OD???
Never heard of that trans. Since you're talking about a clutch, I'm assuming you mean one of the two five speeds, either the M5OD or the ZF.
In either case, the hydraulic clutch system is non-adjustable. The clutch pedal doesn't have to be the same height as the brake pedal.
Besides, how do you know the brake pedal isn't 1/2" too high?
Old Jul 25, 2005 | 06:11 PM
EPNCSU2006's Avatar
EPNCSU2006
There is a lever arm that is splined on the master cylinder side of the clutch linkage. If nothing else is worn or broken, the lever can be replaced ($20 from Ford) and the pedal can be placed where you want it. Check the plastic bushings on the cross-shaft (the shaft running across the pedal box from the clutch pedal to the master cylinder pushrod) for wear and also check the plastic bushing on the master cylinder pushrod. Watch for free-play in the shaft as you push the clutch pedal. Fix the bushings first, then if all those are normal, try a new lever arm for the master cylinder pushrod. Or, if the master cylinder pushrod is adjustable, then do the adjustment there. I don't know if Ford made an adjustable pushrod, though, so that might not be an option.
Old Jul 25, 2005 | 07:04 PM
rews2's Avatar
rews2
There is an adjustable pushrod, I have one on my 88 bronco I also have the M5OD. The adjustment is kind of hidden under the safety switch that forces you to push in your clutch pedal before starting. I'm not sure what range of years the adjustable pushrod came on though.
Old Jul 25, 2005 | 07:37 PM
jeffwecker's Avatar
jeffwecker
oops, i meant M50D,,, SORRY
tbugher62
Jul 18, 2013 06:52 AM
79 f700 370 2v
Large Truck
Jun 3, 2010 12:25 PM
csangster
May 5, 2010 02:46 PM
Brown Falcon
Mar 18, 2009 01:04 PM
sidecar marty01
Jan 9, 2003 07:54 PM
