Glow Plug Circuit - Diagnostic Codes
Old Jul 25, 2005 | 12:46 PM
John_1953's Avatar
John_1953
A while back my 2000 Ford Excursion SES Light came on, the only code showing was P0676. I could clear the code, but it would eventually come back. I checked the codes yesterday and there were 4: P0676, P0673, PO678 & PO674.
With the 1 code I thought it was probably the Glow Plug. Now, with 4 codes I'm not sure. Would Glow Plugs start going out at the same time? Is there something else I should check? Is there someway to further isolate the problem, or should I just replace all of the Glow Plugs.
The truck runs fine, I have abouy 110K on it.
Thanks in advance!
Old Jul 25, 2005 | 01:25 PM
mech2161's Avatar
mech2161
Glow plug failure #'s 3,4,6 & 8
Old Jul 25, 2005 | 04:39 PM
John_1953's Avatar
John_1953
Well, after some addtional research in these fine forums, it seems that Glow Plugs last about 100K. It does not seem to be the relay as I think that would throw a different code. Looks like I can pick-up Motorcraft Glow Plugs at O'Rielly for $8.49 ($8.99 @ Autozone). It does not seem to be a difficult process. Any tips or tricks when changing the Glow Plugs on an Excursion?
Old Jul 25, 2005 | 09:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
In south central Texas you don't need glowplugs to start the engine, but if they're turning on the SES you probably should change them anyways.
It is as straight forward as it appears unless one gets stuck in the hole or a tip breaks off. Then you'll need some tips and tricks.....but those eventualities are also covered in this forum and a little more additional research will find those answers too.
Old Jul 26, 2005 | 12:25 PM
John_1953's Avatar
John_1953
Yea, I didn't think I needed them much around here. Maybe a couple days during the winter. The code for the #6 popped up a couple months ago. I would periodically check the codes to see if anything else may have happened. It was after an extensive driving vacation that 4 of them popped up. After I clear the codes, it takes a day or 2 for the light to come on again, and usually not right after start-up, but after driving a bit.
Old Jul 26, 2005 | 05:02 PM
RedStroker6's Avatar
RedStroker6
did my plugs a while back. not too bad, just took the time. heres a good site for instructions on the plugs and wealth of other info. don't know if you had it yet or not... http://pages.prodigy.net/stevebaz/_i...az/index3.html
Old Jul 26, 2005 | 05:11 PM
Max1775's Avatar
Max1775
I've considered putting in a switch to eliminate my plugs except when it's cold, thought it may make them last longer. Anyone have any thoughts on this?
Max
Old Jul 26, 2005 | 05:22 PM
RedStroker6
yeah, didn't the guy with 3 turbos on his PSD have a write-up on his site about that?
Old Jul 26, 2005 | 05:29 PM
Max1775's Avatar
Max1775
I'll have to look for that, thanks for the tip.
Max
Old Jul 27, 2005 | 10:53 AM
John_1953's Avatar
John_1953
Thanks for the link! Great Site!!
ScaldedDog
Sep 9, 2014 07:23 AM
GreenTerracePSD
Aug 7, 2014 09:13 PM
St Pete Bumper Man
Mar 1, 2014 06:46 PM
PADoubleX
Nov 11, 2013 10:20 AM
planders_99
Aug 6, 2008 07:01 PM
