Neutral Safety Switch
Old Jul 25, 2005 | 11:47 AM
53Merc's Avatar
53Merc
Lightbulb Neutral Safety Switch
I did the safety lane at the Syracuse Nationals a week ago and was reminded I had no Neutral Lockout on my tranny...so I can start in any gear!
I have a 5.0L/AOD set up from an '86 Lincoln MkVll and a Mopar Clip and Steering Column.
What's the easiest way to install a switch so I can't start the engine anywhere but Park? [Do I have the right name for this?]
GW
Old Jul 25, 2005 | 11:59 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Yes you have the right name for this.
Most newer steering columns have a provisions for a nuetral safety/back up light switch on them. The typical mounting point is low on the column below the ignition switch.
Good luck
Bobby
Old Jul 25, 2005 | 12:00 PM
bobbytnm's Avatar
bobbytnm
OOPS..I didn't ask if you had column shift or floor shift. my info applies to column shift.
What kind of shifter are you using? floor, column, aftermarket, etc?
Bobby
Old Jul 25, 2005 | 12:02 PM
Huntsman's Avatar
Huntsman
I could be wrong but I was thinking the aftermarket floor shift kits came with neutral saftey switches. Anybody know for sure?
Old Jul 25, 2005 | 12:08 PM
LEckart's Avatar
LEckart
Ron Francis Wireworks makes a neutral safety switch that mounts on the transmission. You might look at it if you don't have the safety switch on the column. I used one on a ch**y trans once and it worked ok.
Old Jul 25, 2005 | 12:09 PM
bobbytnm's Avatar
bobbytnm
Huntsman, I believe you are right. Ithink allof the aftermarket shifters come with provisions for a nuetral safety/back up light switch
Old Jul 25, 2005 | 12:44 PM
krautwolf's Avatar
krautwolf
Aftermarket Shifters - safety switch
B & M has 'em. It only works if you wire it up.
Old Jul 25, 2005 | 12:56 PM
merc546's Avatar
merc546
53Merc
The backup lamp switch and the neutral safety switch are located togeather on a AOD trans (well at least on my 87 AOD)
They are located on the drivers side about midway and they stand vertical.
The diagram I have here shows a P/O and a BK/PK wire code? but then on the start/ignition wiring diagram they show a R/LB coming from the start side of the ignition and a W/PK going to the starter relay.
I will try and trace mine (it's covered in the new wire loom) and get back to you.
I know it works because I had it running Friday and I don't have the steering column installed now (getting ready for paint)
Old Jul 25, 2005 | 01:17 PM
53Merc's Avatar
53Merc
Arrow
Bobby
The column & shifter are Mopar, the shifter is on the column.
I'll look a tthe tranny too.
GW
Old Jul 25, 2005 | 01:20 PM
Okiedokie's Avatar
Okiedokie
Yes, your AOD is set up for the Nuetral safety/backup switch to plug in where merc546
said. I got mine with the trans [cut the wires]. With a continuity tester it is easy to determine which is N.S. side. Then wire inline between ign. switch and ign. side of starter relay. I even used the backup switch side for backup lites mounted under the truck. Joe
Old Jul 25, 2005 | 01:25 PM
bobbytnm's Avatar
bobbytnm
53Merc,
It sounds like you have several options to go with, either the switch that goes on the trans or the swich that mounts to the column
Good luck with it
Bobby
Old Jul 25, 2005 | 01:40 PM
merc546's Avatar
merc546
Ok got it.
There are 4 wires at the switch 1 R/LB (start side of ign switch),2 W/PK ( use one to go to starter relay) and 1 BL/PK (backup switch)
I have a older Ron Francis kit and just ran the 2 wires to the n/s switch points on the fuse block.
Old Jul 26, 2005 | 05:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GW
GW,
I'm using a Mopar column from a 5th Avenue and unfortunately the neutral safety switch was mounted on/in the transmission on those cars. What I did was use an old lever type backup light switch for a neutral safety switch. I made a bracket to mount the switch down near the transmission linkage and positioned it so that the lever on it is activated only when the column shifter is in park. This means you can only start in park, not park AND neutral, but I am willling to live with that. There are better and more expensive ways to go but this works for me...
Vern
Old Jul 26, 2005 | 07:22 AM
53Merc's Avatar
53Merc
Thumbs up
Originally Posted by GreatNorthWoods
GW,
Vern
Thanks Vern,
I have the same column [the price was right ] and someone in Syracuse suggested a similar fix...which is what I'll get around to eventually I'm having too much fun driving right now
Vern & all:
Since the Mopar Column & the AOD both use a tranny driven system, is it possible and easy 'nuff to adapt the two?
GW
LMK
Old Jul 26, 2005 | 07:55 AM
Okiedokie's Avatar
Okiedokie
53merc, the nuetral safety switch on the AOD does not involve the column. You confused me with the comment on the Wire Works panel. All you need to do is interupt the wire from the ign. switch to the starter relay. The switch on the AOD senses park or nuetral. Joe
