1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
AC!!! Where is the low presure valve?
Old 07-24-2005, 07:54 PM
superstar's Avatar
superstar
superstar is offline
I have a 99Expy EB 2wd. I want to know where is the low presure valve located. Is it the one by the radiator on the passenger side. It has a black cap on it. Is so let me know. Thanks.
Old 07-24-2005, 08:11 PM
924x2150's Avatar
924x2150
924x2150 is offline
I don't know, I have a 92 F150, be careful you may be looking at the fuel line test port. Traditionally, red is high, blue is low. The low side "port" is usually near the accumulator and your cab evaporator, these components are in the low pressure side of the system as these are after what is known as the orifice tube.
Basically, high pressure exists in the compressor output and hose, condensor and hoses, and up to the orifice tube, the orifice tube is not a recognizable feature except it may be indicated by a machining crimp in one of the tubes leaving the condensor.
The evaporator is usually hidden away in the blower box, it is the device that cools the cab. The accumulator should be visible, and it may look like a big capsule and should have an electrical connector with two wires coming from it. The low side port should be near one of these components or just upstream or downstream as you follow the AC lines.
Old 07-25-2005, 06:11 AM
ChiliPalmer's Avatar
ChiliPalmer
ChiliPalmer is offline
2000 Expy 2wd.....I just had mine worked on and the low side was in the back towards the fire wall. WARNING!!! I thought my freon was low and it turned out to be over filled. Anybody know any good AC guys in the Raleigh NC area?? at a fare price?
Old 07-25-2005, 06:29 AM
BigMan69's Avatar
BigMan69
BigMan69 is offline
As 924X2150 had said, it is on the accumulator. Stand on the passenger side and look at the firewall. There is an electrical box hanging on the firewall, look underneath for the accumulator (the low pressure port is right on it). It is real tight unless you have tiny hands. Better to move the electrical box a bit to gain clearance. If you are refilling yourself, make sure, at the least, you get a refill kit with the gauge attached so you don't overfill (overpressurize) the system.
By theway, what you were looking at is the high side port.
BigMan69
Old 07-25-2005, 07:42 AM
Freak4Ford's Avatar
Freak4Ford
Freak4Ford is offline
Look on the passenger side, near the firewall. There maybe a hose blocking your view. I can't remember if its near or on the accumulator but if you find the accumulator then the service valve is right there. The accumulator is a silver oblong shaped device attached to the firewall.
Old 07-25-2005, 01:16 PM
superstar's Avatar
superstar
Thumbs up
Thanks for all your input. I will go now and look for it. Thank you
mustang9701
02-02-2014 09:50 PM
tjbjeepn
06-06-2013 09:31 AM
hardwaterfreak
12-22-2011 07:56 PM
George D.
17
04-03-2008 10:48 PM
rosa70
07-05-2005 09:16 PM
Quick Reply: AC!!! Where is the low presure valve?
