code po470 and po478
Old Jun 30, 2005 | 07:06 PM
rosa70's Avatar
rosa70
I get those 2 codes through my Superchips tuner. I know they are for the exhaust back presure sensor error and valve high output. What I need to know is where is that sensor located in the EBPV and what else could cause that problem to show up in the codes. Could it be the buterfly getting stuck. Any info on this would help. Thanks
Old Jul 5, 2005 | 01:54 AM
soutthpaw's Avatar
soutthpaw
need vehicle info to help out
Old Jul 5, 2005 | 12:24 PM
rosa70's Avatar
rosa70
Vehicle is a 2001 F250 2wd. I just keep getting these codes over and over after clearing the codes with the tuner.
Old Jul 5, 2005 | 01:08 PM
mech2161's Avatar
mech2161
P0470 is sensor circuit malfunction. P0478 is excessive pressure during normal driving. The sensor is to the left side of the HPOP just behind the drive belt.
Old Jul 5, 2005 | 09:16 PM
nodakford's Avatar
nodakford
DTC470 and DTC478
Continuous DTC P0470 indicates an exhaust back pressure malfunction was detected during normal driving conditions.
Possible causes:
-- damaged EBP sensor
-- damaged connection
-- damaged PCM
DTC P0478 indicates an excessive back pressure condition existed during normal driving.
l Possible causes:
-- stuck EBP butterfly valve
-- restricted exhaust
-- plugged EBP sensor line
-- misadjusted EPR linkage
-- F-Series wastegate turbo may be overboosting
bobpick
Feb 15, 2010 03:34 PM
john8403
Nov 10, 2009 08:15 PM
bigcrunch
Oct 12, 2009 06:30 AM
rocky3539
Apr 20, 2007 03:52 PM
PLatreille
Feb 13, 2005 01:11 PM
