Lowering 62 Rear End
Old Jul 24, 2005 | 07:31 PM
62 red truck's Avatar
62 red truck
Today I started to lower my rear end.I'm going to flip the axles.
I have 5 main springs and 3 over loads.Any advice on which springs to remove for a smooth ride?
62 F100, s/box
4.6 with auto
IFS THANKS Larry
Old Jul 24, 2005 | 09:06 PM
jd_sylvia's Avatar
jd_sylvia
I dumped the overloads on mine installed new U bolts and what a differance in ride. It is a lot smoother and quiter.
jd
Old Jul 25, 2005 | 04:25 PM
gangstakr's Avatar
gangstakr
lose the overload springs and flip it. are you c-notching? how low are you going?
I did the flip and c-notch I sit real low but the ride is worth it to me.
Old Jul 25, 2005 | 10:29 PM
62 red truck
Thanks for the info,I may have to "C" it. I have a crown vic K member so with any luck it will set about the height of a crown vic. thanks again Larry
Old Jul 25, 2005 | 10:51 PM
gangstakr's Avatar
gangstakr
c-notch
check my gallery my 64 has volare front fliped rear c-notched and boxed I like the way it sits low but not uncomfortable she cruises real good.
Old Jul 26, 2005 | 05:18 AM
62 red truck
Robert,can you get some pictuers of the rear springs and the C notch.My first time doing this.What about the shocks,do you know what was used? I assume they must be shorter than stock.What a great steering wheel.I'll be looking for something like yours.Know where any F100 SABER jets are parked? A really sweet truck. Thanks Larry
Old Jul 26, 2005 | 09:17 AM
66MercMan's Avatar
66MercMan
I have some pics of my c-notch in my flairside gallery. Not the same truck but you get the picture. I just welded a new perch on the underside of the axle, you can buy them at most hot rod shops. and cut the old one off. then unhooked one side of each leaf spring and slid the axle in over top. Make sure you mount the new perch to give the same pinion angle as the old. I replaced my ubolts and made them a little longer in case I want to add blocks and go lower.
Old Jul 26, 2005 | 10:53 AM
gangstakr's Avatar
gangstakr
c-notched
hey Larry, I uploaded a picture showing c-notch it's not the best picture but I hope it helps.
Old Jul 26, 2005 | 09:34 PM
62 red truck
Thumbs up
Robert, nice job,great notch really clean,nice pipes I really like the tips.Thanks for posting the pic,it will be a great help. Larry
Old Jul 27, 2005 | 09:17 AM
66MercMan's Avatar
66MercMan
Sorry, my albums were hidden by admin. Here is the pic.
Old Jul 27, 2005 | 09:12 PM
62 red truck
66mercman,Thank You for the picture it will be a great help when I start cutting.I see you have 4 projects,if you get a chance I would like to see your finished trucks.I get most of my ideas from the Pro's.I printed the pic out. Thanks Again Larry
Old Jul 29, 2005 | 03:41 PM
Tiremine's Avatar
Tiremine
62 red truck,
I flipped the rear axle on mine and did the C-notch a liitle different. Pics in my gallery. May give you another option. Good luck and keep us posted
Old Jul 29, 2005 | 09:20 PM
62 red truck
Steve,thanks for the pic,Great Truck.I do like the flip and "C".I printed your pic.Will be used when I start cutting.I can only hope mine comes out as nice.
THANKS AGAIN Larry
