Does anyone out there have info on the gear ratios on a NP 540 trans. I know some of these units are overdrive, some arent. The first gear ratio determines whether or not it is an O/D, but I can't find info about the other ratios, or whether mine is O/D. 2700 RPM at 70 mph in 5th gear with a 3.54 rear gear along with really tall tires can't be O/D ing. I'd really like to know what all the ratios are in this trans, not just what fifth is. My trans is a 7.41 :1 first. Any ideas? thanks a lot.
...Welcome Buck Rogers, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I "Googled" NP 540 just about every combination I could think of. What did you do that I didn't? Thanks a lot for the info. I've gotta decide what to do with this thing, this trans just isn't working out with my engine and truck combo. This will really help.
