1978 - 1996 Big Bronco
Running too rich
Old Jul 23, 2005 | 05:51 PM
DMBronco's Avatar
DMBronco
Running too rich
I just got a smog check on my '94 Bronco. It barely passed the HC text, which they tell me means it is running too rich. Is there an adjustment that can be made to correct this, or is there likely a bigger problem?
I appreciate any pointers.
thanks
-david
Old Jul 23, 2005 | 10:46 PM
JetBlackBronco's Avatar
JetBlackBronco
most likely its the o2 sensor, its a cheap part, so just replace it, if that dosent fix it, pull the codes and see what you get
Old Jul 24, 2005 | 11:55 AM
kameronth's Avatar
kameronth
The o2 sensor is around $50. Before you fork that out I would pull the codes. It is very easy to do and will usually lead you close to the problem.
Rij1
Nov 4, 2016 01:07 AM
Cdy1
19
Jun 8, 2015 12:30 AM
bmoran4
May 13, 2015 03:35 PM
gearhead242
Jul 9, 2009 09:01 AM
dcdave
Jan 27, 2004 11:18 AM
