Running rich, failed smog
Old Nov 1, 2016 | 04:58 PM
Rij1's Avatar
Rij1
Took my truck to get smogged today and it failed. Seems to be running too rich at 15 miles per hour in first gear and at 25 miles per hour in 2nd gear. I did kept this nipple that I seen uncapped cuz my truck is running really rough and that actually smoothing it out like it normally would run. Can I get any help on this?
Old Nov 1, 2016 | 07:52 PM
Franklin2's Avatar
Franklin2
Take the aircleaner off and while it's running look down the carb throat. Do you see liquid gas dripping into the engine?
Old Nov 2, 2016 | 05:23 AM
Rij1's Avatar
Rij1
I'll give it a shot in the morning.
Old Nov 2, 2016 | 05:24 AM
Rij1's Avatar
Rij1
Would adjusting the pilot screw help in the 1800 range?
Old Nov 2, 2016 | 05:54 AM
Franklin2's Avatar
Franklin2
If you are talking about the mixture screw on the carb no, it only adjusts the mixture at idle. If you have a on purpose vacuum leak(cap off) somewhere, the mixture screw probably won't do much at idle either.
Old Nov 2, 2016 | 03:00 PM
1986F150six's Avatar
1986F150six
Photo #1 reveals a vacuum leak. Look at the rubber cap on the vacuum tree on the intake manifold [near the O2 Sensor]. Check all rubber and plastic vacuum lines for additional cracks. While at it, check the two bolts which secure the carburetor to the EGR adapter. They tend to vibrate loose and create another vacuum leak. These engines run poorly when a vacuum leak exists.
Your engine is computer controlled [based on the O2 Sensor]. Our forum moderator, Chris Tubutis, gave me this link which shows how to get the computer to tell you what might be wrong. http://www.therangerstation.com/tech...ry/OBD_I.shtml
Old Nov 2, 2016 | 04:46 PM
Franklin2's Avatar
Franklin2
Your engine is computer controlled [based on the O2 Sensor]. Our forum moderator, Chris Tubutis, gave me this link which shows how to get the computer to tell you what might be wrong. Ford Ranger - Testing EEC-IV Equipped Engines
He said in the first post that he intentionally left a vacuum port open to suck air to make it run better. I am wondering if he has float problems and uncontrolled fuel going into the engine.
Old Nov 3, 2016 | 03:31 PM
Rij1's Avatar
Rij1
Update. Just to pass smog. I loosened the carb mount bolts and Unplugged that cap I put on. It almost passed smog but the timing was too high now and I forgot to lower the idle speed so maybe that's why the timing was high. 1st pic is the first test.
Old Nov 3, 2016 | 05:13 PM
Franklin2's Avatar
Franklin2
You are letting it suck air everywhere to help the air to fuel ratio. You will never be able to idle it down by doing that. The carb is supposed to control the air entering the engine. It can't do that with all that air sucking in around the loose carb and the uncapped vacuum lines.
I know you are just trying to get it to pass, but I think you need to do some more troubleshooting.
Old Nov 4, 2016 | 01:07 AM
Rij1's Avatar
Rij1
Yeah, this situation sucks right now cause I broke both my hands and can't tear into this truck like I normally would. I need to be able to use the truck for doctors and what not. Maybe I will just have to take my time and do what I can do and do it right.
jbarefoot
Flathead V8 & Flathead 6
Jun 15, 2011 11:36 PM
shark1979
Apr 20, 2009 06:28 PM
74 F100 351m
Jan 9, 2004 09:03 PM
