1978 - 1996 Big Bronco
question about rearwindow not working
Old Jul 21, 2005 | 02:35 PM
the Goat's Avatar
the Goat
My rear window went down today and now refuses to go back up. I have the "tailgate closed" sensor bypassed so it is not that. My question is if the dashboard switch breaks can it stop the tailgate-key-switch from working?
My dashboard switch has been on the fringe for a few months now. I have just been using the keyswitch to roll the windows up and down. But now that isn't working either.
Any sujestions?
Old Jul 21, 2005 | 05:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 21, 2005 | 07:30 PM
gungho351's Avatar
gungho351
The switch might have shorted out on you, causing the key not to work either. I had that problem a while ago, just bought a switch from broncograveyard.com
Old Jul 22, 2005 | 04:40 AM
Bronco Dale's Avatar
Bronco Dale
window/ latch trouble
I had that same trouble with the rear window. I found the rear tailgate was not latching tight, thus not making a good connection for window switch. Try pushing in on the tailgate (carefull not to dent middle as I did!) as you try the key switch. If that works as you push in on tailgate then your latch bars are loose inside the tailgate. Easy fix! Take tailgate liner inside off to expose bars and doorlatch. Slightly bend bars back to proper arch so tension is increased on latch. Then tailgate should close properly and thus switch makes contact again! Kind of a cheap setup, but it is easy to fix. Same exact trouble and fix on drivers door latch I found. Hope this helps.
Old Jul 22, 2005 | 08:23 AM
bigbronco88's Avatar
bigbronco88
i also have the same problem ,my 88's rear window will go down ,but it only go's back up about 8" ,you can here something back there as if it is trying to go up ,
but no luck going all the way up
sorry to jump your thread ..but i thought i fit right in there
i will take the tailgate panel off today to see what the deal is
Old Jul 22, 2005 | 08:49 AM
chaindog's Avatar
chaindog
might check the inside handle to see if it is down tight
Old Jul 22, 2005 | 09:12 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Lightbulb
BigBronco88, if you can hear the motor running, chances are the plastic motor gears are stripped. Very common problem. The fix is to get a gear kit and replace the gears. I bought mine from the dealer, but since then many parts stores have started carrying them......
Old Jul 22, 2005 | 03:04 PM
the Goat's Avatar
the Goat
Well I replaced the dashswitch and it still wont work.
The bronco is going in for some work on monday anyway so my guy will have a look at it and see if he can find the problem.
Old Jul 23, 2005 | 01:07 PM
thenewjohndeere's Avatar
thenewjohndeere
you might check your wiring under the driverside tail light ... i ran into the same problem and the wiring ended up being old and brittle (snapped in half when i touched it) ... i cut the bad spots out and ran some more wire and it works great now
Old Jul 24, 2005 | 10:22 AM
Gurahl's Avatar
Gurahl
Also check the fuse. I don't mean to insult your intelligence, but after reading about motors going out and bad wiring all the time I didn't even bother checking the fuse until I was outside of the shop I was taking it to.
Gurahl and his Bronc'nstein
Old Jul 24, 2005 | 12:01 PM
Bronco Dale
Wink The Obvious
Sounds like something I would do. It is easy to overlook the obvious. My son could not get his inside dome and panel lights on, was checking fuses,ect. Was going to take it in to shop and I walked up to the light switch and clicked them on! He did not know you could switch them off so they would not come on when you opened your doors. I read a post that someone could not get his inside lights to come on, I wonder???
