efi troubleshooting..please heeelp
Old Jul 23, 2005 | 09:34 AM
dunwithit's Avatar
dunwithit
Question efi troubleshooting..please heeelp
hey everyone,i have a 1986 f-250 302 4x4 runs fine at an idle and about to half throttle thenit bogs down real bad it will stay running tho.i change the fuel pump,regulator,filter,theres no pump in the tank just frame mounted one.i am stumped and anyone i asked is also stumped please help thanks bob
Old Jul 23, 2005 | 12:57 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
Old Jul 23, 2005 | 12:59 PM
dunwithit's Avatar
dunwithit
thank you,.
Old Jul 23, 2005 | 02:02 PM
220k-f-150's Avatar
220k-f-150
First thing would to find, borrow, buy you a fuel pressure testing gauge. Hook it up to shchrader valve on fuel rail. And test for fuel pressure. Sounds like a fuel problem though. Hang in here, you might get a few other suggestions.
Old Jul 24, 2005 | 11:02 AM
Trial and Error's Avatar
Trial and Error
I have 86 F150, 302 efi . It has what I call a dead spot in the accellerator where it will lope like it has a fuel problem or a clogged filter. It only does this at a certain speed, i.e. about 20 mph sustained speed. Filter has been replaced and fuel pressure checked normal. I've had it for 3 years and I have spent a ton of money on various parts which have done nothing to fix the problem. I am more aquainted with carbureted vehicles and if it were carbureted, I would say ithe carb is worn out and is sucking air. I know little about efi, however, and I dont know if a worn out throttle block would do the same thing. I replaced the idle air control on it but that didn't do anything , nor did the new tps. I have decided to stop spending money and drive. It starts and runs fine except for this one small problem. I believe you can dollar and dime yourself broke trying to fix one of these old trucks with a primitive electronics system. No codes are stored.
Old Jul 25, 2005 | 09:20 PM
dunwithit's Avatar
dunwithit
thanks for the reply,i replaced the fuel pump,filter,and pressure valve but still nothing,maybe it got a bad pressure valve think im going to try the test gauge thing ,any other suggjestions? im open lol ,next i replace the motor lol
Old Jul 25, 2005 | 10:00 PM
SmokyOlFord's Avatar
SmokyOlFord
Loose distributor cap, weak plug wires. Is the timing advance working?
-Ed
Old Jul 25, 2005 | 10:04 PM
dunwithit's Avatar
dunwithit
nope i replaced the wires plugs,cap roter and the whole distributor it dont have vacum advance on it so im not sure how the advance works
Old Jul 25, 2005 | 10:05 PM
220k-f-150's Avatar
220k-f-150
beyond a fuel pressure problem. Vacuum leak, egr bad.
Old Jul 25, 2005 | 10:10 PM
dunwithit's Avatar
dunwithit
i couldnt find any vacum leaks, i checked each hose in water with air pressure,new egr on top,but i didnt replace the can under it
Old Jul 25, 2005 | 10:19 PM
dunwithit's Avatar
dunwithit
i even have the fte stumpped lol
Old Jul 25, 2005 | 10:20 PM
220k-f-150's Avatar
220k-f-150
A little confused. You replaced the sensor on top, but not the EGR valve.
Old Jul 25, 2005 | 10:30 PM
wojo44's Avatar
wojo44
some help maybe
i would go to www.fordfuelinjection .com its a great site and it can help u with any efi prob u might have .
Old Jul 28, 2005 | 12:09 AM
locknkey's Avatar
locknkey
Don't forget to reboot the computer after you changed your parts and do the 30 min road test to reset all your sensors...30 min battery disconnect, then road test. Get a digital code reader, and post your codes after the rebooting and road test...you might get it fixed sooner instead of throwing parts at it and wasteing your money...
Old Jul 28, 2005 | 10:55 AM
SmokyOlFord
I had my dizzy cap off for inspection. Found a flaky plug wire while at it. I put the cap back on, a few days later I noticed I clicking that could be felt in the distributor. I found one side wasn't even connected, I put it on wrong! Just something to check.
-Ed
