smoke
Old Jul 22, 2005 | 05:55 PM
fumaito's Avatar
fumaito
smoke
any one know why i have smoke coming from the dipstick on an 86 6.9 f350 and if so how it fix it.
Old Jul 22, 2005 | 08:26 PM
fordborn's Avatar
fordborn
"fumaito" - Welcome to the site, there should be plenty of people to help you with your question soon.
Thread moved to proper forum to ensure more response to question.
Old Jul 22, 2005 | 10:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
fumiato, Welcome to FTE.
When you say you have smoke out of the dipstick tube, do you mean when the dipstick is in it?
Probably just normal blow by, but.....
There is a CDR valve on the back of the intake throat under the air cleaner. It is held on by two bolts and has a tube that goes down into a grommet in the valley pan. The CDR is the same thing as a PVC valve on a gas motor. They should be cleaned out every couple of oil changes so they don't get gunked up with oil deposits.
I take mine off the engine and drop it in a coffee can with enough gasoline to cover it completely. Let it soak for an hour or two. Then take it out and hold you fingers over the two open lines with some gas still in it, but not clear full. Shake it around and drain the gas back in the can. Repeat this a couple of times. Then drain all the gas back in the can and lay it out to dry out. DO NOT BLOW COMPESSED AIR INTO THE CDR. There is a diaphram that will be ruptured and ruin the CDR. After it is dried out, reinstall it.
Old Jul 27, 2005 | 09:56 PM
fumaito's Avatar
fumaito
thanks
hey thanks for the info about the blow-by.one more question my oil pressure some mornings it is high and some it is low when the truck has been running all day at 190 temp the oil pressure is real low i was wandering what it could be by the way it is a rool back tow truck thanks
waystro
Mar 2, 2012 08:18 PM
Crash1040
Nov 28, 2006 05:16 PM
crack
Aug 30, 2006 07:43 AM
bronco cam
1978 - 1996 Big Bronco
Jan 13, 2003 01:52 PM
TonyG
Jun 22, 2002 08:46 PM
