1978 - 1996 Big Bronco
Blue Smoke
Old Jan 12, 2003 | 02:47 PM
bronco cam's Avatar
bronco cam
Blue Smoke
Old Jan 12, 2003 | 07:26 PM
Broncman93's Avatar
Broncman93
Blue Smoke
Hey Guys --- I have a '93 Ford Bronco and it died. it acted like the battery was dead. i got the battery recharged, changed the spark plugs, and changed the battery connections. After that it started but barely idles. When it does run there is blue smoke coming from under the firewall where the engine goes under the car. PLEASE HELP !! Im in college and dont have a ton of money so i would like to keep it out of the garage. Thanks a lot guys !!
Old Jan 12, 2003 | 10:06 PM
blownbronco's Avatar
blownbronco
Blue Smoke
Well, Blue smoke indicates oil burning, and since you said under the firewall I would say the smoke is caused by a cracked oil pan or broken rear main seal. the oil pan is more likely though because that would dump alot of oil which will cause you to have no oil pressure which causes bad idle!!! Hope this helps...
Old Jan 12, 2003 | 10:46 PM
greystreak92's Avatar
greystreak92
Blue Smoke
To ad to what blownbronco said...if that IS indeed the case, don't run her for long with severly decreased oil pressure! That will ensure a costly repair bill.
Old Jan 13, 2003 | 09:56 AM
Broncman93's Avatar
Broncman93
Blue Smoke
sweet, thanks a lot guys. I turned my heater on high also and i smell gas about half and half (exhaust and gasoline). Is there any more ideas? Also if i must take it to a garage there is one about 100 yards from where it is. Would it be safe to drive? How much does a typical oil pan change or seal replacement cost? Are there any other signs for me to look for to tell me if it is definatly one or the other? Thanks. You guys are the best.
Old Jan 13, 2003 | 01:52 PM
alanscott's Avatar
alanscott
Blue Smoke
Check your exhaust system for a blockage, maybe someone shoved a potato up your exhaust pipe.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
