Aerostar Ford Aerostar
stalling after start
Old Jul 22, 2005 | 03:10 PM
jjessen1's Avatar
jjessen1
Over the last week I just recently started having a problem. Last Saturday, I started my van and then it died right away. I started it again, stepped on the gas a little and it stayed started. It drove fine. It has now gotten to the point that I need to step on the gas when I start it and slightly rev it for about the first minute or so before it will keep running on it's own, but at a very rough idle. When I am driving, it is fine. But at stop lights or when stopped on the highway, I will notice the idle drop almost as if it wants to stall then. I've asked my bf to look at it several times, but I don't think he's looking at the right things. He's more looking at spark plugs, distributor cap....and from the reading I've done, it sounds like it might be the IAC. Could someone please tell me where it is located on the 93 Ford Aerostar so that we can check it? Also, does that sound like it may be the problem, or could it possibly be something else?
Old Jul 22, 2005 | 08:39 PM
93nighthawk's Avatar
93nighthawk
welcome!
First, loose your bf, he must be a bow tie guy.
Second, what you describe definetly sounds like your IAC going bad. It is a cylinder thing attached on the intake right next to the throttle body.
You did not mention if it is a 3.0 or 4.0?
Old Jul 22, 2005 | 08:41 PM
93nighthawk
Site acted up???
Old Jul 22, 2005 | 09:19 PM
Backyard Mech's Avatar
Backyard Mech
The IAC might be going bad... or it might be sticking. Get some throttle body cleaner (or maybe SeaFoam) and spray into the small side ports next to the butterfly while engine is running.
Since your engine has a MAF sensor (at least a 93 SHOULD, I'd think), you will want to warm the engine, stop it, disconnect the MAF harness, remove the intake tube, then start engine to do it.
If a good spray-down has no effect you need a new actuator at the least.
Wont hurt to clean the MAF while you're at it.
See SeaFoam Deep Creep Thread
{dang! THIRD EDIT!} Just had a thought... my son had a similar problem. My mind must have been clearer then... because I advised him to try removing the MAF harness and seeing how it reacted and drove.
In his case, it didnt stall with the MAF disconnected. So I had him clean the MAF and that fixed it.
Reason I suggest this is that a sticky or bad IAC resulting in low idle means that the car usually wont start easily either.
Old Jul 25, 2005 | 08:30 AM
jjessen1's Avatar
jjessen1
It's a 3.0L engine.
p.s.....bf is gone now
Old Jul 25, 2005 | 07:58 PM
93nighthawk
So how u doing? (in joey voice.)
Old Aug 5, 2005 | 10:15 AM
jjessen1's Avatar
jjessen1
OK, bf back. Changed the spark plugs. Won't check the IAC (maybe because of ego) However, this is what it's been doing since....
Starts easier now. Once vehicle is driving and it gets hot, it wants to die. It stalls when pulling into a parking spot, stopping at light, slowing to turn a corner, etc. When I stop at a stop sign, I have noticed the check engine light come on, but then it turns off as I am driving. It's also sucking up the gas
Old Aug 5, 2005 | 02:54 PM
Dracoscott's Avatar
Dracoscott
compared to changing the plugs, IAC is a piece of cake.
Old Aug 5, 2005 | 02:58 PM
tom_foreman's Avatar
tom_foreman
Have you looked for a loose vacuum hose?
Old Aug 5, 2005 | 03:00 PM
jjessen1's Avatar
jjessen1
You know, He has now found 2 hoses that weren't hooked up to anything that he can't figure out where they go to
Old Aug 5, 2005 | 03:38 PM
Bear River's Avatar
Bear River
Former ******
Well, a vacuum hose diagram (sticker under hood) should tell where they go.
Old Aug 5, 2005 | 04:41 PM
Muffinman's Avatar
Muffinman
Anytime it back fires it can blow the hoses off the tree. It's located on the driver side upper rear intake.
Old Aug 7, 2005 | 09:58 PM
xuzme720's Avatar
xuzme720
you can pull stored codes from that check engine light, as well, if you can get a code reader... or just use the jumper method described in most manuals. that may point you in a better direction. but the vacuum leak will do just what you describe ....BTW any problems w/ shifting? if so, one line could be to the modulator on the tranny. if not, most likely both are from the PCV tree. pull the doghouse (access panel under the dash) for better access to the rear of the engine. good luck
Gary
sulldog66
Aug 26, 2008 03:10 AM
JWest
Dec 4, 2007 03:35 PM
bobg28bobg
22
Apr 7, 2006 10:29 PM
wolfehunter
Nov 20, 2003 11:52 AM
brent091
17
Jul 5, 2003 07:26 PM
