valve sizes
Old Jul 21, 2005 | 11:46 PM
MMarty's Avatar
MMarty
valve sizes
I am getting ready to build a 77 400 and I have a set of 72 351c heads to put on. They need rebuilt so do you think I should have 400 valves installed or keep the c valves? OR just overhaul the 400 heads? This is going to be a low buck build but I am going to spring for flat top pistons and a cam. Speaking of which, I will be doing a stock type valve job, can I use the comp cam with the stock (NEW) springs? BTW Is there a big difference in valve sizes between the C heads vs the 400? Thanks, Marty
Old Jul 22, 2005 | 09:34 AM
mark a.'s Avatar
mark a.
There really isn't any difference in the heads if the clevland heads are 2v. The '77 heads should have valves with the single groove valve keepers, which is what you'd want. The 77 heads may have valve rotators on the exaust valves, you don't want those left on there. I'd get the springs that the mfgr. recomends for the cam, they don't cost much.
Snorri_B
Feb 14, 2012 09:29 PM
nothercrash
Dec 7, 2009 08:24 PM
redsuperduty
Jun 7, 2009 09:14 PM
77F150Jason
Sep 28, 2006 07:51 PM
66ford400
May 30, 2005 02:50 AM
