Bore and Stroke??
Old Jul 20, 2005 | 09:41 PM
thegreenmachine5's Avatar
thegreenmachine5
Bore and Stroke??
What kind of power can be produced out of an inline six block if it is bored and stroked?
Old Jul 21, 2005 | 01:19 AM
optikal illushun's Avatar
optikal illushun
boring doesnt do much for power. its there to clean up the cylinder bores to make them true, clean and crosshatched.
stroking the 300 is useless. its already a 4.00" stroke. the cranksfhat would need to be offset ground and custom rods would be needed. Clifford has a stroker kit...note the term, HAD.
SilverStreak mentioned he had a stroker kit in his skunkworks but kept hush hush about it. in theroy it could work but the 300 is set up good as it is. its an almost square engine which, IIRC, is good for making oodles of torque and being efficent.
Old Jul 21, 2005 | 10:01 AM
thegreenmachine5
yeah, your right, how much torque does the 4.9 make? I love mine, you just can't kill it!
Old Jul 21, 2005 | 11:41 AM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
between about 250-270 ft lbs depending on carb'd or efi and what year.
Old Jul 21, 2005 | 01:19 PM
Silver Streak's Avatar
Silver Streak
I never had a kit, I just have some ideas I want to try. I'm pretty sure I can get around 350 cubes without getting real exotic. Just have to get time. I don't think I was very hush hush about the stroker stuff. I'm pretty sure all my thoughts are documented here. There are some intake, exhaust and other things I'm reluctant to disclose until I get results. Getting my timing gears changed is the next thing on the list. Looks like I'm gonna have to settle for coarse tooth gears. The only place I found fine tooth listed was on Comp's website and that was a lie.
Old Jul 21, 2005 | 03:19 PM
optikal illushun
well i know how u are about those intake/exhaust ideas so i took a guess. ah well.
Old Jul 21, 2005 | 03:23 PM
greengeeker's Avatar
greengeeker
whatever you do, don't swap it for a v8.
Old Jul 24, 2005 | 10:59 AM
thegreenmachine5
I really love my I6 but I am wondering how well it will perform if I run 36" tsl with 4:56. I think it should be fine. Any thoughts.
Old Jul 24, 2005 | 12:26 PM
optikal illushun
what tranny?
pud
Oct 7, 2006 01:20 AM
wiles1947
Jul 19, 2006 01:08 AM
jstrauss
Nov 15, 2002 10:25 AM
BigBrownTruck
Modular V8 (4.6L, 5.4L)
Feb 24, 2001 09:55 PM
donsboy
Jan 17, 2001 06:33 PM
