370ci 385 series
on
Hi and Welcome to FTE! Please take a moment to check out the Guidelines, they contain important information that you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
I've moved your post to the 385-series forum where you should be able to get more info.
I found a late 70's model truck that has what I think is a 3704V. Would the manual fly wheel fit on a 460? I don't think it's a 429 motor. It appears to have the longer snout on the end of the crank. Not sure if the 429 truck motors had this or not.
I was told when I was younger that these motors had steel cranks and if you turned the crank snout down you could run it in a regulaer 385 series engine. Any truth to this?
actually only the 429 truck motors had the steel crank, the 370 had a cast crank (with the rare exception of coarse of one that was accidently put together with a steel crank because someone happened to grab that instead, Ford was good about those types of things and almost nothing is an absolute)
One major advantage to grabbing a 370, that the block is just like all the rest of the D9TE blocks with the exception of it is only bored to 4.05 instead of 4.360, so if you happen to have say a good rotating assembly out of a standard bore 460 you can take that 370 block and bore it standard adn put the rotating assembly into it, disclaimer here though you can only use the externally balanced rotating assemblies as the earlier internally balanced units with not work without major clearencing. This can be a major advantage to guys that are working in CID limit rules racing that say have to stay below 465cid or some stupid number like that (rules that are intended to keep the BBF guys from bieng able to rebuild thier motors and encourage teh chebbie guys), so you could build a standard bore 460 with performance parts and not have to pay big money for a new block.
Originally Posted by monsterbaby
One major advantage to grabbing a 370, that the block is just like all the rest of the D9TE blocks with the exception of it is only bored to 4.05 instead of 4.360, so if you happen to have a good rotating assembly out of a standard bore 460 you can take that 370 block and bore it standard adn put the rotating assembly into it...
The 1979-up 429/460 blocks are casting number D9TE-AB, while the 1979-up 370 block is a D9TE-BB casting. There is not near enough material in the cylinder walls to bore this block to 4.36", as it was engineered to have a 4.05" bore and can not be bored anywhere near .300" over.
Wish I had a picture with the freeze plug removed so that y'all could see the Grand Canyon gap between the cylinders.
Paul
Paul, I rarely disagree with you, and guess I haven't seen the BB designation blocks so it might be different, but we just got done last spring building a 429 using a 370 block and punched it to 4.360 ( the guy had a set of standard bore forged 429 pistons) so that might be something to check on because I know that atleast some had the regular D9TE-AB block.
Wouldn't surprise me at all if Ford used a D9TE-AB for a 370 when there were no 370 blocks to keep production moving...but a D9TE-BB block cannot be bored to 4.36"...none that I've seen.
Also, your info kills my typical search technique of looking for 429 truck cranks, now knowing that I may indeed buy the Lima engine from a dismantler just because it's a D9TE-AB block...only to find a cast crank in it.
Paul
Paul
Santiagoeford
07-24-2015 08:19 PM
big block power
12-21-2002 01:37 AM
jstrauss
11-15-2002 10:25 AM
