Cold cranking vacuum reading.
Old Jul 18, 2005 | 07:05 PM
Pinkster1's Avatar
Pinkster1
302 marine engine, Stock fresh rebuild. won't idle below 1200rpm unless I squirt a little extra gas and I can get it down to 700rpm.
So either carb issue or serious vac leak.
I have taken the Holley 2300c apart several times after I gave it a fresh rebuild, and everything checks out. I've tested for vac leaks while running engine@1200rpm
by spraying carb cleaner around base, head interface and back and front of manifold and no rpm increase. When engine is warmed up, valve covers will breath vapors, so I don't think there is an internal leak. Plus I have 7psi fuel while cranking and float is set correctly.
What I did was, take a piece of Lexan and place it over intake with some vac grease, and got a cranking vac reading off the PCV port of 14"-15" for a cold, not broke-in engine, So I assume that's pretty tight. I then put the carb on, back off the throttle stop so blades are closed, and turned the idle jets in. Cranking vac was 5"-7"
So I'm loosing ~7" vac with carb. There are only two ports under the blades and there on the base. One feeds the choke and the other I think is dead.
The throttle shafts seem relatively tight. base gaskets fit correctly.
Any ideas?
Thanks
Old Jul 19, 2005 | 08:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to engine forum.
64F-100
16
May 4, 2019 01:28 AM
ghostshark
17
Sep 18, 2016 01:23 AM
drmgoat
18
Nov 11, 2008 10:35 AM
daveengelson
Jul 7, 2006 08:05 PM
turboseamus
Dec 26, 2004 08:33 PM
