maximum RPM for engine.
Old Jul 17, 2005 | 05:40 PM
surveyboy's Avatar
surveyboy
new to diesels, but not to fords. owned 3 gassers before this all with 460's. whenever hauling, a steep grade normal procedure is to put it in 1st or second and go. with the 460's usually I never usually pulled around over about 3000 RPM's.
now with my new 6.0 and 5 spd auto, just wondering what's the max RPMs these motors should turn at? I'm ASSuming near the 3000 mark but, just wondering.
thanks
Old Jul 17, 2005 | 06:31 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
3000?! Are you kidding?
I will refer you to my standard gallery picture for this subject...
It'll stay there all day. The days of diesels redlining at 2700 RPMs are over, thankfully, even though there are alot of other members who don't like to accept that
Old Jul 17, 2005 | 08:07 PM
obxtuna's Avatar
obxtuna
This is sick.......
Old Jul 17, 2005 | 08:15 PM
ford390gashog's Avatar
ford390gashog
i hope you are not manually shifting your torqueshift like that. there is no need to start out in first. the torqueshift is a awesome automatic tranny and requires little if any operator input other than pressing the tow button.
Old Jul 17, 2005 | 10:37 PM
Brian460's Avatar
Brian460
thanks
Mine sees 4000 on a regular basis.
Did you say the 460's never saw much over 3000rpm?
Old Jul 17, 2005 | 10:38 PM
Brian460's Avatar
Brian460
thanks
Also note PSD 60 FX4's shift indicator's position
Old Jul 17, 2005 | 11:03 PM
surveyboy's Avatar
surveyboy
Originally Posted by obxtuna
This is sick.......
well, I've been reading for about a week in this forum, and haven't found that info.
the 460's that I have owned haven't seen time over 3000k rpm very often or for very long when I have gotten them that wound up. call me paranoid.
I shifted the old E30D tranny that way, cause, basicly, it sucked and I was doing my best to take care of it. I haven't shifted my new torqueshift like that other than to see where the power stops in each gear. I know that new ones are MUCH better than the old 3 spd with OD.
that's great to know that I can turn them at 4k and not be worried.
thanks for the info.
sb
Old Jul 17, 2005 | 11:12 PM
Brian460's Avatar
Brian460
My 460 saw 5500-6000rpm everyday.
The tranny BTW is an E4OD.
Ford390gashog is right put the Torqshift in drive and floor it you'll like it. LOL
Old Jul 17, 2005 | 11:26 PM
SpartanDieselTech
Former Vendor
That is the actual 1-2, 2-3, and 3-5 upshift shift points It hits overdrive at 4250 instead of 4475 to keep boost up...
Old Jul 17, 2005 | 11:27 PM
surveyboy's Avatar
surveyboy
that's right, E4OD. my bad.
I've always tried to be ultra easy with my trucks.
Old Jul 17, 2005 | 11:31 PM
Wekiwa's Avatar
Wekiwa
My dad's F350 dually with the Tow Boss package (4:30 gears) rarely hits 3500 when dragging the 14K lb 5th wheel around. Cruising is about 2100 if I remember correctly. The 6.0 makes most of its torque below 2200 in stock form.We rarely exceed 70 mph because he doesn't like crosswind effects.
Mine (3:73 gears) stays about 2300 or so when empty with cruise set slighty above the posted speed.
Wekiwa
Old Jul 17, 2005 | 11:33 PM
SpartanDieselTech
Former Vendor
You can't reasonably overrev the 6.0 in stock form. They are rev-limited to 4000 by the PCM (far below the safe limit), and it would be nearly impossible to do it mechanically with an automatic transmission. The only way it is even possible is with a 6 speed by downshifting in an obnoxious fashion.
Old Jul 17, 2005 | 11:40 PM
surveyboy's Avatar
surveyboy
cool. I think I'm gonna like this 6.0
haven't come close to the rev. limiter yet. still below 400 miles on it LOL.
Old Jul 18, 2005 | 12:15 AM
DavidT.'s Avatar
DavidT.
Talking
A little off topic, but just thought I'd share an image of my Honda road course car. It's not the original motor in the car but it has untouched internals, sees 9k all day long on a track day
Old Jul 18, 2005 | 10:39 AM
04 LARIAT STROKER's Avatar
04 LARIAT STROKER
i frequently hook my 04 to the sled and rev it up to the redline and hold it there for the whole pull....the 6.0 loves rpm's
rustygold1
Jun 4, 2014 07:18 AM
jonluc1
Apr 13, 2014 07:51 AM
F-250 WARHORSE
Jul 29, 2012 06:59 PM
steekers
Jun 20, 2011 02:09 AM
