Carb rebuild kit
Old Dec 2, 2002 | 02:53 PM
bluemustang's Avatar
bluemustang
Carb rebuild kit
I have a 1975 f100 with a 390 was a 360, 2bbl with electric choke. I'm try to find a rebuild kit for it, but my carb is missing the tag on the front. I went to NAPA and took the carb with me and they could not help. In the book they had we did not see a 75 truck with a 360 in it. Can any body help me, I need to get it rebuilt. Does any one else have this set up that I can get there tag number.
This is the info I do know about it. The Factory ID number is 30EA, the Venturi Size 1.0S and it has a short Snout.
Thanks David
Old Dec 2, 2002 | 03:07 PM
dfisher1's Avatar
dfisher1
Carb rebuild kit
Dave,
Do you know what the name brand is? Motorcraft?, Carter?
Traditionally one rebuild kit will rebuild a given family of carbs.
The 390 carb and 360 should be the same, short of the jet size, accelerator pump linkage , etc.
Scan a picture of the thing and I'll take my best shot at identifying it.
KingFisher
Old Dec 2, 2002 | 03:45 PM
bluemustang
Carb rebuild kit
Sorry about that, it's a motorcraft and I have a picture of it in my picture Galley. You can see it use to have a tag, but I had it redone a long time ago and the I guess they left the tag off.
Old Dec 2, 2002 | 04:28 PM
Mil1ion's Avatar
Mil1ion
Carb rebuild kit
There should be a number stamped into he airhorn of the carb.
My Guess for a KIT = Motorcraft CT-1077D
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 2, 2002 | 04:48 PM
jearl's Avatar
jearl
Carb rebuild kit
Basic code should be D5TE- followed by 2 or 3 letters ie. BYA. this code should get you close
Old Dec 2, 2002 | 06:45 PM
mk's Avatar
mk
Post Carb rebuild kit
Some previous owner may have put a different carb on it. The model should be a 2150 Motorcraft. You should have a venturi size stamp of 1.12 on the left side of the float bowl for your size engine. I've found as well that Ford usually stamped the part number on the left side front corner of the bottom flange. Where did you get your factory id number? And what do you mean by 'short snout'?
mike
Old Dec 3, 2002 | 08:05 AM
bluemustang
Carb rebuild kit
mil1ion I will check the air horn and see if there is a number. What carb type is this Part number for. Thanks
jearl, can I use the BYA for my carb? Do you what type of engine it came off of. Thanks
mk, The carb is a 2150, I got the ID number from left side front corner of the bottom flange. The Venturi size stamp is showing 1.0s,
Check the link out below.
[linkhotos.yahoo.com/bc/windhamdw/vwp?.dir=/Truck&.src=ph&.dnm=Carb.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/windhamdw/lst%3f%26.dir=/Truck%26.src=ph%26.view=t|Yahoo Link]
Old Dec 4, 2002 | 10:10 AM
bluemustang
Carb rebuild kit
mil1ion, I checked the Air Horn last noght and I didn't a number.
Old Dec 4, 2002 | 06:57 PM
mk's Avatar
mk
I believe the only carbs Ford had with an air horn stamped number were the Holleys. That number on your flange is probably a 3DEA but I think that E may be something else. They are hard to read. The float bowl stamping is supposed to be all numbers, like 1.05, maybe. I still think that it's too small for a 360.
mike
Old Dec 4, 2002 | 09:02 PM
Mil1ion's Avatar
Mil1ion
Carb rebuild kit
The re-build kit I mentioned earlier should cover the one you have, as it covers over 150 numbered carbs from the era.
Dennis
[font color=red]
[/font]
Old Dec 5, 2002 | 03:02 AM
Ford_Six's Avatar
Ford_Six
Carb rebuild kit
A 1.05 is right for a small-port 360, and corresponds to about 350cfm. The 1.5 is for the 390 and big-port 360's, and is about 410cfm.
Jared
Old Dec 5, 2002 | 07:20 AM
bluemustang
Carb rebuild kit
I looked at it a little closer last night and it was a 1.08.
Old Dec 5, 2002 | 03:10 PM
jearl's Avatar
jearl
Carb rebuild kit
Dennis is right the rebuild kit he mentioned for a 2150 should work. other than minor changes to adjustment (idle,et.) everything else pretty well the same and the rebuild kit doesn't come with any jets or needles that would vary between carbs in the same series.
Old Dec 5, 2002 | 04:12 PM
bluemustang
Carb rebuild kit
I will go to the parts store and give it a try. Just to make sure how can I tell if it's a 2100 or 2150 or what is the difference between the two?
Old Dec 5, 2002 | 06:42 PM
mk's Avatar
mk
They modified the 2100 slightly for emissions in the mid seventies, I think, and called it a 2150. Carb kits are pretty universal for these if you have rough idea of the year. That 1.08 is the same as the factory stock carb on a 71 302 I have. By the way, I've never heard of 'small port' or 'big port' 360s. Has anyone else? The biggest venturi size I've heard of for a 2100/50 is 1.21 but maybe there is a one a hair bigger. Never heard of a 1.5.
mike
