best way to decrease turbo lag
Old Jul 17, 2005 | 12:29 AM
ktplotts's Avatar
ktplotts
Not sure if the older ones have the turbo lag like the 05's, but i need to do something about mine. It is only bad when i'm towing at least 5k lbs. and it will hesitate for a good 3-5 seconds before really moving.
Right now the truck is stock and has 10k miles on it. So what is the cheapest most effective way to reduce the lag?
Old Jul 17, 2005 | 06:45 AM
WWBeast's Avatar
WWBeast
unplug the EGR? I could be wrong but i have been readin alot on it although most of the stuff doesnt say anything about the 05 mostly on the 04 and 03, but i unplugged mine a little less lag. so hope that helps
Old Jul 17, 2005 | 08:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Buy a tuner for it like an SCMT
Old Jul 17, 2005 | 09:37 AM
Customz's Avatar
Customz
You can powerbrake for instantaneous boost, but I second the SCMT
Old Jul 17, 2005 | 09:56 AM
Whopper809's Avatar
Whopper809
performance turbo back exhaust will reduce turbo lag quite a bit.
Old Jul 17, 2005 | 10:01 AM
Vic_Ferrari's Avatar
Vic_Ferrari
It will certainly help, but there is a great deal of throttle lag controlled by maping that must be tuned. There is no throttle cable, everything is "fly by wire".
Old Jul 17, 2005 | 10:04 AM
Spaznaut's Avatar
Spaznaut
A good exhaust will help get the turbo moving quicker. Be aware that you could void your warrenty with any aftermarket work ya do. Just be prepared to remove stuff if you have a mod un-friendly service dealer.
Old Jul 17, 2005 | 11:11 AM
Rodslinger1's Avatar
Rodslinger1
Just to let ya know, turbo lag on an '05 wasn't lessened by my turbo back install - at least with the muffler and cat still in place. Is it true disconnecting the EGR helps? I may give that a try to check it out.
Old Jul 17, 2005 | 12:10 PM
Viper TT's Avatar
Viper TT
The largest improvement in the turbo lag area that I found was removing the cat! The MBRP turbo back made a slight improvement and the Edge made another small improvement. But removing the cat made the most significant difference in turbo spool in my scenario.
Old Jul 17, 2005 | 11:51 PM
Brian460's Avatar
Brian460
I didn't notice any less lag with my 4" turbo-back until I got a SCMT!
Old Jul 18, 2005 | 04:32 AM
kw5413's Avatar
kw5413
It helped mine.
Old Jul 18, 2005 | 06:13 AM
Rodslinger1
Alright thanks kw5413, then I guess I'll give it a shot and see what happens. It can't hurt anyting to discinnect it.........right?
Old Jul 18, 2005 | 07:20 AM
Mark Oomkes's Avatar
Mark Oomkes
Ditto on my '05. Still trying to find a definitive answer. It isn't too bad without a trailer, but as soon as it's hooked up, it's terrible.
I did disconnect EGR, no difference. With all the different answers it sure gives credence to the snowfalke theory.
Just imagine if Microsoft designed Windows and had all these problems where basically no 2 operating systems (engines) were alike. New upgrades\patches (reflashes) every other week that fixes some problems and not others.
Old Jul 18, 2005 | 07:28 AM
Vic_Ferrari
It is almost like that, believe it or not.
LOL
Old Jul 18, 2005 | 07:33 AM
Mark Oomkes
Do you mean Microsoft or Ford?
