power steering and map sensor question
Old Jul 15, 2005 | 07:25 PM
goodwrench's Avatar
goodwrench
Question power steering and map sensor question
1987 f-150, 300-6, four speed. I am slowly weeding the problems out of this truck, and have a few questions. First the idle has been a little rough and seemed to me like it wasnt right down low(like below 2500 rpms). Well while reading chiltons i discovered the power steering pressure switch and the probs it can cause, so i unplugged it while running, the idle changed a bit and it ran alot better. So, what does the switch tell the computer? And what does the comp do about it? And secondly, the map sensor. Chiltons say two types of these early voltage varying and later frequency varying. Which would i have? I checked it the first way with the voltage, and i had 4.? volts to it, then with no vaccum it read 2.? volts and then with vaccum applied the voltage never changed? So is it brain dead? Or is it the frequency type? Also if you pinch the hose while running it will die(or almost wanted to i released it before it did). Do i need to replace it or does it sound like it is functionong right? Okay enough for now, i will save my tps questions for later. So help!!
LAter chris
87oldtimer
Jun 7, 2014 05:37 PM
blueray
24
Apr 13, 2013 07:54 PM
kirkharrod
16
Feb 25, 2010 07:36 AM
wlihntr
16
Apr 13, 2004 01:40 AM
irishman200232
Jan 21, 2004 03:29 PM
