Save money! Aeroforce gauge instead of 3 gauges!
I just got an Aeroforce Interceptor Scan Gauge! WOW! It is great! It will replace 3 of my IssPro gauges (Trans temp, boost, coolant temp). Prolly put them up for sale on FTE classifieds.
The scan gauge has 19 parameters that you can read from the OBD2 port. No external power needed! Just plugs into the OBD2. It was about $240. So you can save the price of the 3 gauges, and the price of the 3 gauge pillar and it MORE than pays for itself.
It has 2 displays on the gauge and each can be configured to scroll 4 parameters, so you can have it scroll 8 values. Also, you can hook 2 of them up together and scroll 16 values. It reads trouble codes and resets them. It can also record the values while you drive so you can check them later. It does more stuff I haven't even figured out yet!
Here's what it reads:
1. INTAKE AIR 2- Intake Air Temperature taken at the throttle body inlet
2. COOLANT TEMP 2- Engine Coolant Temperature
3. RPM 2- engine Revolutions Per Minute
4. MANIFOLD PSI 1- Manifold Air Pressure (psia) for voltage based MAP sensors
(mid 1990’s trucks).
5. Manifold PSI 2 – Manifold Air Pressure (psia) for frequency based MAP sensors
6. BOOST 1 – Boost Pressure in psig for voltage based MAP
7. BOOST 2 – Boost Pressure in psig for frequency based MAP
8. MILES PER HOUR 2- Miles Per Hour
9. TRANS TEMP 1- Transmission Temperature for 1998 and newer trucks
10. TRANS TEMP 2 – Trans temp derived from the trans temp sensor voltage for 1997
and older trucks.
11. TRANS VOLTS – Transmission temperature sensor raw voltage.
11. RUN TIME MINS- engine run time since last engine start. Can be used as a trip
timer.
12. BATTERY VOLTAGE- Alternator/battery output voltage
13. PULSE WIDTH- injector pulse width in msec.
14. ENGINE OIL TEMP
15. EX. BACK PRESS – Exhaust back pressure
16. ICP DC – Injector Control Pressure Duty Cycle
17. ICP – Injector Control Pressure
18. INJ. TIMING – Injector Timing Deg BTDC
19. CURRENT GEAR – Current Transmission Gear
Let me know if anyone has any questions!
and older trucks.
timer.
14. ENGINE OIL TEMP
Aeroforce Technology Inc | Products - Sensors
No, there is no sensor on the 7.3L that will allow you to view any kind of EGT's.
Yes, they have add on sensor kits for wideband O2 sensors, EGT, etc.:
at $165 for both = $414 for a single gauge that can provide 2, 4, 8 or 16 values. I'm just thinking out loud here. This is in the range of a 3 gauge kit with a pillar pod. I just happen to be one who doesn't fancy the multi-gauge pod thing and have been looking for mostly digital alternative. DashDaq is way cool but dang expensive. GlowShift has a 3-in-1 for $169:
3 in 1 Multi Diesel Gauge - Boost, Exhaust Temp, Temp Diesel Gauges
Riffraff has the BullyDog Outlook for $356:
Riffraff Diesel: Bully Dog Outlook Monitor
So many choices... I need more coffee.
I am noticing that! The Interceptor lists coolant as a parameter but it is not accurate. I started the truck this morning and the coolant temp parameter said 200.
