2001 Expy mis while stopped in gear
Old Jul 15, 2005 | 01:31 PM
TCarson17's Avatar
TCarson17
For the last couple of weeks I had a CEL for low flow egr. I vaccum tested the valve it was good. Changed the DPFE did not help checked for clogged ports no problems clean then I replace the vaccum solenoid the light isw off and has not come on for about 60 miles. The surging I had while driving is now mostly gone. However if im sitting at a light in gear at idle it almost missed or like the egr is opening and causing a short quick miss. Idle in park is fine. I have checked all the coils and they are firing fine will the pcv valve cause this.
Old Jul 15, 2005 | 02:04 PM
l-m tech's Avatar
l-m tech
check the pcv elbow at the rear of the intake it could be ruptured.your egr problem with it being an egr regulator solinoid dosnt happen very often.
Old Jul 19, 2005 | 01:50 PM
TCarson17's Avatar
TCarson17
ok update ran fine for 4 days no CEL no back on and missing or hesitating again. I have checked everything that everyone has said. My question when I do vacuum test on EGR valve it kills the engine which means good but could it still be malfunctioning. I still get the flashing CEL which is misfire the it stays on as low flow. All cleaning relaced DPFE vaccuum soleinoid changed pcv and chedked hoses. tried to tak off the egr but there is a line that is in the way that runs from evap above brake booser to back of the motor does that just unplug from the motor. HELP
gtown_will
Jul 27, 2012 08:32 PM
1978Crew
Escape & Escape Hybrid
Feb 18, 2008 01:58 PM
Billy Ray
Jan 15, 2004 03:00 AM
Billy Ray
Jan 14, 2004 05:21 PM
Katt
Apr 13, 2000 07:54 AM
