HELP - Strange IDM Problem
Old Jul 15, 2005 | 09:33 AM
fordf350crazy's Avatar
fordf350crazy
Unhappy HELP - Strange IDM Problem
Let me start from the beginning. 3 weeks ago, my truck was only running on the passenger side cylinders. So I replaced all the wiring harnesses on the drivers side, plus one glow plug pin that was burnt. It ran fine for about 50 miles, then it started doing the same thing, it would shut down the drivers side cylinders intermittenly until eventually, it was running on the passanger side cylinders all the time. So I changed the IDM. The strange thing about it, the old and new IDM will only work when it is not grounded to the fender. If I dont mount it, it runs fine. And if I mount the IDM to the fender, it shuts down the drivers side cylinders. I understand that there has to be a short somewhere, but has anyone witness this problem before? Any suggestions?
Old Jul 15, 2005 | 01:44 PM
touchofgrey's Avatar
touchofgrey
I think you've got a broken wire somewhere in the insulation, or a bad connector on a wire. So that when you bolt the IDM down.....it separates, and it makes contact if it's left in a natural state. Start the engine and move the loose IDM around some......if I'm right.....it should start cutting out. Hope this helps.
Old Jul 15, 2005 | 02:17 PM
fordf350crazy
I have moved the IDM around while its running, and it does not change anything. Maybe Having th IDM not grounded causes a bypass of the IDM shutting down the bank when a short occurs???
Old Jul 16, 2005 | 03:13 PM
MDB's Avatar
MDB
Ohm each of the pins on the drivers side valve cover connectors to ground to check them for correct values. On the 95 there are two connectors, each with 5 pins. Pins 1 & 5 are for the glow plugs, and should have from 2-5 ohms resistance to ground. Pins 2, 3 and 4 should not have any resistance to ground (infinity), and if they do you still have a wiring problem somewhere.
I don't recall exactly, but I think pins 2-3 and 3-4 should be about 25 ohms to each other. Pins 2 & 4 are each for an injector, and pin 3 is the ground reference for these two injectors. This means that if any of these 3 pins is grounded somewhere, you will get a very similar reading from all three of these pins to ground.
If this checks out ok, you probably have a problem somewhere in the external wiring harness between the engine and IDM. Good luck.
Old Jul 19, 2005 | 11:46 AM
fordf350crazy
Thanks MDB. I will try this process of elimination.
I wish that the shop had done this before buying a new IDM. Now I am stuck with a brand new $850 IDM. Anyone interested in buying this at a discount?
Old Oct 18, 2005 | 09:13 PM
ceopi's Avatar
ceopi
Unhappy
Mine is doing the same thing..Did you find the problem...Thanks
Old Oct 19, 2005 | 11:14 AM
fordf350crazy
It ended up being some burnt injection wires that were shorting out. I would check that out THOUROUGHLY first, before you buy any parts.
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
cherrybomb37
23
Jun 20, 2014 08:09 AM
Mdt1992
15
Jan 16, 2012 09:07 PM
89ford73
Jun 3, 2008 10:22 AM
fordf350crazy
Jul 14, 2005 12:31 PM
