4.9 in 76 f250
I assume you mean the inline 6 300 cid engine with fuel injection. If so, it should be a bolt in swap as far as the engine goes. That block was offered in a carbed version in 76. Now the hard part. What engine and trans are there? Will you be swapping the trans from a doner vehicle? Do you have the entire vehicle to pull parts from?
The easiest way to do it would be to have a donor vehicle to work from. Then you have a matching trans, a wirning harness, the computer and other electronics, possibly the fuel pump and rear end.
It should be a do-able swap.
BigWhite76
10-01-2014 10:23 PM
VaFordman26
01-09-2013 07:28 AM
oldblue31
06-10-2004 09:10 PM
79 390 highboy
05-23-2003 01:00 PM
