Sponsored by: Innova
CD Player in 76
Old May 22, 2003 | 11:24 PM
79 390 highboy's Avatar
79 390 highboy
CD Player in 76
Does ne know if there is a install kit for a 76 f250. Or a easy way to put in a cd player.
Old May 23, 2003 | 07:47 AM
optikal illushun's Avatar
optikal illushun
CD Player in 76
no mounting kit that i know of, but it shouldnt be to difficult. do u have a good knowledge of wiring? if so then it'll be a snap...
Old May 23, 2003 | 08:57 AM
carlos694x4's Avatar
carlos694x4
CD Player in 76
No mounting kit needed.
If your dash is factory all you should have to do is cut a standard Din size hole in the dash, wire it up and go.
Use the basket for the new CD player as a template and trace around it where you want the hole, i like to use an air saw, it cuts a nice clean hole, you can also use a dremmel tool or tin snips depending on your dash.
Old May 23, 2003 | 01:00 PM
79 390 highboy
CD Player in 76
thanks alot guys
Whitey Ford
Jan 15, 2013 12:23 PM
Oscar Meier
Jul 18, 2007 10:26 PM
Mitzilplic
Feb 25, 2003 09:42 AM
xtra1es
Dec 24, 2002 05:10 PM
logan_85
Jul 18, 2001 05:59 AM
